Folding Wall For Garage/Shop Separation - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By smithwcnj
Old 07-27-2016, 12:11 PM   #1
Rewards Points: 4
Folding Wall for Garage/Shop Separation
Have a 3 car garage that will be separated for a shop. I plan on building a folding wall (like many High School Gyms have used) out light weight steel framing studs. I am looking for suggestions on a light weight material to cover it with and add turgidity to the frame.
The whole system will be mounted on a roller/track attached to the ceiling.
Any suggestions?
smithwcnj is offline   Reply With Quote
Old 07-27-2016, 12:29 PM   #2
JUSTA MEMBER
Rewards Points: 378
Re: Folding Wall for Garage/Shop Separation
Turgid: Swollen.
What's that got to do with a frame?
How about some sheet steel to add rigidity.
ED
de-nagorg is online now   Reply With Quote
Old 07-27-2016, 12:46 PM   #3
Rewards Points: 100
How wide will ech "panel" be?
Sent from my SAMSUNG-SM-N900A using Tapatalk
ChuckTin is offline   Reply With Quote
Old 07-27-2016, 01:21 PM   #4
craig11152's Avatar
Rewards Points: 1,220
Some sort of 1/4 inch luan type stuff is light weight and if sufficiently screwed in to the steel studs would firm up well I would think.
Don't look at me. I didn't vote for either one of them.
craig11152 is offline   Reply With Quote
Old 07-28-2016, 11:30 AM   #5
Rewards Points: 100
I was thinking the same. "Door skins" on metal framing. Can probably get 2 pieces from one skin.
Old 07-28-2016, 12:04 PM   #6
Rewards Points: 4
Thanks for the replies.
Turgid ? yea auto spell makes up it's own mind.
I was thinking luan as well but was open to other suggestions. Planning to put a 2" foam in the middle to dampen sound and help heating during winter months
de-nagorg likes this.
Joining thin wall abs pipe to standard abs pipe Homerepairguy Plumbing 3 03-02-2015 12:39 AM
Core filling a bowing wall, please assist silverstrike Building & Construction 12 06-16-2012 11:28 PM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 11:32 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
