Floor Is WAY Not Flat - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By joecaption
Old 04-14-2018, 05:44 PM   #1
Rewards Points: 1,664
Floor is WAY not flat
Low budget renovation, 100 year old house, looking at living room left to right, joists running directly away from me. Starting at left, gradually dips and then rises over a length of about 8 to a high point.....and then dips again towards the other end which is an additional 4. So, we have a max depression of around 1 1/2 midway across the larger area and the a straight drop of about 1 over the additional 4.
This activity is only at one end of the room, maybe coming 6 into the room befor thins mostly flatten out. Nothing structural to see from below....and tearing out the joists etc. and shimming up is not an option. Goal at this point is to get it decently flat enough to carpet it and call it a day. Suggestions???. Thanks in advance
ront02769 is offline   Reply With Quote
Old 04-14-2018, 06:11 PM   #2
Guapo
Rewards Points: 11,950
Re: Floor is WAY not flat
Clarification questions:
Are we talking about the living room floor joists that can be seen from the cellar or are you looking at the joists from above?
Is the subfloor still installed or not?
Any pics?
Guap0_ is offline   Reply With Quote
Old 04-14-2018, 06:32 PM   #3
Rewards Points: 18,382
All we did for at least 15 years was work on 100 plus year old houses.
Never once saw a flat or level anything.
Under sized, over spanned, joist, improper footings under piers was the norm.
Unless your willing to spend the time and money to fix it, it is what it is.
Bondo likes this.
Old 04-14-2018, 07:25 PM   #4
Any pics?
First floor, joists see from below, subfloor of one bye planks covered by 1/4 ply with a million staples in it still in place. Ron
Old 04-14-2018, 07:28 PM   #5
Master General ReEngineer
Bondo's Avatar
Rewards Points: 230
Ayuh,.... Floors off that much are Fixed from below,.....
Luckily for you, Carpet won't care, 'n can roll with the flow,.....
Bondo is online now   Reply With Quote
Old 04-14-2018, 07:55 PM   #6
CodeMatters's Avatar
Rewards Points: 7,472
I'm no carpenter but I've seen 4 approaches:
1) Jack it up till level and support.
2) Build new sub-floor shimmed level.
3) Pour on self leveling concrete.
4) Cover it with carpet or vinyl or something else forgiving and live with it.
CodeMatters is online now   Reply With Quote
Old 04-14-2018, 08:26 PM   #7
Rewards Points: 540
I'm in about the same situation. 1920's house. It is wood joists, subfloor and 1x strip flooring, but I am seriously thinking about using cheap mortar, then cover with stick on ice shield to hold all the pieces that might crack. Have thought about leveler but they are all about same weight anyway. Then cover with 3/4 floating floor.
BTW the sagging joists were doubled.
carpdad is offline   Reply With Quote
Old 04-15-2018, 09:09 AM   #8
The funnest leveling attempt I ever saw was when they had installed 5 layers of plywood, thinking that was going to make it flatter.
The home owner lived out of state and keep letting hacks live there letting them have cheap rent of they "fixed" it up.
I looked under the house and all the old brick piers had failed, that was the real issue.
I knew something was up when I walked in and saw what looked like 4", 5/4 baseboards instead of the normal 6" in older homes.
All the doors had also been cut off at the bottom with what looked like a sawzall.
Insulating attic with flat roof under sloped roof syogod Insulation 6 01-26-2017 12:46 PM
Multi-ply deck beam - flat on top or flat on bottom Scott_Va Building & Construction 11 10-09-2016 11:58 AM
Smooth walls with flat paint...looks weird to me? TOTALN00B Painting 3 04-25-2011 06:42 AM
will a flat roof always leak............. cappuccino Roofing/Siding 6 04-19-2011 05:16 PM
Using Flat Paint on Flat Paint that had been touched up with Gloss! Russell_Case Painting 1 01-17-2009 07:58 PM
