Floor Squeaks - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree1Likes
Old 03-01-2019, 04:01 PM   #16
Rewards Points: 2,324
Re: Floor squeaks
Or, try this, it works:
https://www.amazon.com/OBERRY-ENTERP...4Z47Z29731Z6A5
bob22 is offline   Reply With Quote
Old 04-16-2019, 10:29 AM   #17
Rewards Points: 132
Re: Floor squeaks
Originally Posted by Nealtw View Post
On occasion we can have truss lift in the winter, and sometimes the wall will move with the trusses. This is something to be looked at when nothing else solves the problem. This can happen when they nail the trusses to the interior wall instead of using truss lift clips.
So if the trusses are nailed to the interior wall can the nails be removed and have the truss life clips installed if so is this as simple ass removing the nails and installing the truss clips?
2Quiker is offline   Reply With Quote
Old 04-16-2019, 12:16 PM   #18
retired framer
Rewards Points: 13,968
Re: Floor squeaks
I would think that would do it. Might b tricky finding them all, if they added drywall backing up against the truss.
Do not use flat bottom gables with scissor trusses.
Nealtw is offline   Reply With Quote
Old 04-16-2019, 12:27 PM   #19
Rewards Points: 132
Re: Floor squeaks
It seems as most of the floor popping is an area along a certain wall (red line in pic). I will have to go up in the attic and see if i nails holding the trusses or if i see truss clips. I did look at the plans and the county plan examiner did indicated that there should be truss clips along the front porch. When the truss clips are written does that mean all the trusses should have truss clips all the way to the back wall or only in the front where it's written "truss clips"?
Old 04-16-2019, 12:33 PM   #20
retired framer
Re: Floor squeaks
On the end of the truss he meant hurricane ties. Those will be joining the truss to the outside wall where you don't want it to move.
The Following User Says Thank You to Nealtw For This Useful Post:
2Quiker (04-16-2019)
Old 04-16-2019, 01:25 PM   #21
Rewards Points: 132
Re: Floor squeaks
ok, i see. Sorry for all the questions, i am not a builder and i am trying to understand why i have a lot of floor squeaks. So should they have installed truss clips like the ones you posted ( or like this https://www.adheseal.com.au/shop/flo...uss-clips.html) on all the truss in the inside of the house?
Old 04-16-2019, 01:33 PM   #22
retired framer
Re: Floor squeaks
Yes those are what should be used, but this is only one possible cause of a floor squeak and if you fix this, you might get into where the truss lifts and breaks the seam between the wall and ceiling drywall.
