Floor Joist Support Question - Sunken Living Rm - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-03-2009, 08:15 PM   #1
Angry
Floor joist support question - sunken living rm
Hello all,
This is my first post here. The situation is I have a sunken living room floor. after gutting the basement, I found that the joists were notched over the sill plate and only a 2x4 glued/nailed to the foundation wall was supporting the back end of the floor. Has anyone ever seen it done this way?? I was thinking about adding a main beam accross the end wall (about 16ft) with jackposts and blocking between the joists. see pic below to understand what i mean. need opinions, thanks.
see pics of what i mean here: http://www.diychatroom.com/members/j...lbums/my-pics/
jedrph95 is offline   Reply With Quote
Old 06-03-2009, 09:41 PM   #2
Registered User
Rewards Points: 526
Good idea to stiffen the joists. If the space is not being used below, I would build a 2x4 wall, pressure treated bottom plate and double or triple top plate. Space the studs at 32" on center, or 16"o.c., under each joist with one top plate. You don't know the slab thickness or hidden bearing (if any) for a post and beam frame. The blocks in this case are required to hold the joists from rotation, because the rim doesn't extend the full thickness of the joist.
http://www.bssconline.org/Homebuilde...e/Chapter4.pdf Page 5. Be safe, G
replacing molding in sunken living room floor lokidawg Flooring 7 08-07-2009 01:41 PM
Filling sunken living room w/ concrete Q's phil. Building & Construction 5 07-10-2009 12:03 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
Modular (not Mobile) home renovation question mommybradley Remodeling 5 01-03-2008 12:55 PM
Hardwood flooring - 3 walls and a sunken living room basledder Flooring 1 12-09-2007 05:34 PM
