Fixing A Dirt Crawl Space - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-18-2009, 07:24 PM   #1
fixing a dirt crawl space
We have a small room approx18x9 room atttached the the house has heat, but it has a dirt crawl space. Would it be best to concrete it, or dig it out and pour a foundation to match the basement
pjpckmcov is offline   Reply With Quote
Old 08-18-2009, 08:43 PM   #2
Rewards Points: 3,622
MUCH easier to place a vapor barrier on the floor/walls & insulate the floor joists,,, also MUCH less expensive than the 2nd choice,,, caution - you MAY need power ventilation,,, just my $0.03, tho
Old 08-18-2009, 08:47 PM   #3
How deep is the crawl space right now?
Digging out is no fun - did it some at my last house
Any water pipes in the crawl space?
If not I'd do as already posted
What is holding it up right now?
Concrete walls around the perimeter? Other?
Jacking Up Floor Joists in Tight Crawl Space killerformula Building & Construction 2 06-11-2009 03:23 PM
Crawl Space Insulation skinny2 Building & Construction 10 12-12-2008 11:36 AM
Inadequate center support in tight crawl space 4just1don Building & Construction 5 09-28-2008 03:29 PM
Crawl Space - to vent or not? tomandlu Building & Construction 2 01-15-2008 07:23 PM
Crawl Space In Basement -- Please Help thekid Building & Construction 7 01-04-2008 08:15 PM
