Fix Roof Boards? - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Nealtw
Old 06-08-2018, 03:18 PM   #1
Rewards Points: 152
Fix roof boards?
This roof configuration has a real problem: with rain, the corners where the roof edges meet have gotten rotted out.
Is there a good solution for this?
I figure I can replace parts of the boards, at minimum.
Is there some gutter/drain solution that would prevent this in the future?
Siwash is offline   Reply With Quote
Old 06-08-2018, 05:10 PM   #2
retired painter
Rewards Points: 1,816
Re: Fix roof boards?
The drip edge doesn't look adequate. Not sure if it's how it was installed or just needs to be bigger. A little more overhang with the valley flashing would also help.
Is the rot limited to the fascia boards?
mark sr is online now   Reply With Quote
Old 06-08-2018, 05:29 PM   #3
retired framer
Rewards Points: 6,172
I would replace all that is need with a new drip edge in that area and extend the metal valley out over the drip edge about 1 1/2" with 1/4" bent down at the end to make a drip edge,
Siwash likes this.
Roof repair versus reroof and which contractor to believe? miamicuse Roofing/Siding 42 01-12-2015 10:05 AM
Repair + roof coating options Fishbone90 Roofing/Siding 23 11-12-2012 10:44 PM
Carport Lean to Roof Question.. jgcable Building & Construction 31 04-29-2011 06:12 PM
Roof leak nightmare..... it won't stop amandat37 Roofing/Siding 52 04-22-2011 01:47 PM
Putting a new flat roof on a 3600 sf home Jean3 Off Topic 2 04-09-2010 01:35 AM
