Fireplace Framing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-14-2015, 01:21 PM   #1
i carved this sword
feralfreak's Avatar
Rewards Points: 169
fireplace framing
is there a place I can see the framing of a fireplace area? I want to see how its done and what the code says for it.
feralfreak is offline   Reply With Quote
Old 09-14-2015, 02:26 PM   #2
Rewards Points: 144
Google is your friend.
mako1 is offline   Reply With Quote
Old 09-14-2015, 02:33 PM   #3
Rewards Points: 5,012
Wood, gas etc..?
Mantle yes, no.?
ron45 is offline   Reply With Quote
Old 09-14-2015, 05:23 PM   #4
i carved this sword
feralfreak's Avatar
Rewards Points: 169
it would burn wood and I would want a mantle, and I would want to be able to put a wood stove insert in it so it would still burn wood, have the option to use it if I cant find an insert that fits, and if I can, find one that I can cook on(I heard there was one called a ben franklin stove insert)
Old 09-14-2015, 06:13 PM   #5
Rewards Points: 5,348
You're going at this bass ackwards. Look at the various types available and then look at the directions to install them.
They will include all the information needed.
There is no information for, "I want a fireplace, how can I frame it out".
Ron
B. Franklin 1759
Old 09-14-2015, 08:08 PM   #6
feral,
Can't help with the fireplace personally but this may keep you busy for awhile.
http://www.woodworkersworkshop.com/r...lace%20mantels
Here's many projects.
http://www.woodworkersworkshop.com/r...ex.php?cat=102
Here's lots more.
http://www.familyhandyman.com/woodwo...e=1&display=49
This is a good site and you can look around for many projects all at the top of the page.
http://community.familyhandyman.com/f/default.aspx
I hope this will keep you busy...
Fireplace Smell ...help wanted ! jasonb72 General DIY Discussions 9 10-15-2018 07:16 AM
Question regarding likely framing behind fireplace on exterior wall JKeefe Building & Construction 11 01-07-2014 02:39 PM
Efficient framing and framing lumber Geran Brown Building & Construction 13 11-17-2013 02:24 PM
Fireplace w/ TV focus point. Stone to ceiling or not? POLL 6fthook Interior Decorating 2 05-25-2011 10:02 PM
fireplace framing sonic_loser Building & Construction 1 11-02-2007 01:35 AM
