Finishing A Mud Room - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-09-2010, 02:37 PM   #16
Rewards Points: 150
just wanna throuw this out there too. the wall are framed at 20 oc. what do i do about insulating???
cut/stuff 24"wide in then??
basically do i need a solid vapor barrier?? which i could achieve by cutting down or stuffing 24 in there or should i use unfaced and run a solid vapor barrier over it??
organick is offline   Reply With Quote
Old 12-09-2010, 05:58 PM   #17
Rewards Points: 5,348
Unfaced and a 6mil vapor barrier.
Ron
Old 12-09-2010, 08:53 PM   #18
Registered User
Rewards Points: 526
What State do you live in?
The U.S. Energy Code requires exhaust ventilation for laundry rooms, Your State may or not. The location would also tell us if you need a vapor barrier on the walls or not. One is required under the bricks/slab, as I said earlier.
Gary
Old 12-09-2010, 10:18 PM   #19
Rewards Points: 150
GBR
I live in NC......
I was told by an inspector on another thread that the ventilation is not required because there is no attic space above the room???
There is no poured concrete etc under the block....maybe a gravel bed but I don't think anything else. So i assume no vapor barrier.... So it seems like you are saying look no more because the foundation is not acceptable???
Also there is not access to under this floor the wall shared by this room and the kitchen is where the crawl space ends...
Insulating a cold/well room? Lynch Building & Construction 23 07-25-2014 02:49 PM
Finishing basement laundry room DIYguy2000 Building & Construction 7 12-04-2009 11:56 AM
First Question: How to cool this room? Warhammer: 3025 HVAC 4 03-25-2009 10:02 AM
Vents from boiler room RammsteinNicCage HVAC 3 03-11-2009 07:28 PM
A room in a room? artosie General DIY Discussions 2 03-10-2009 12:43 PM
