Finish Basement Wall Ideas... Help - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree5Likes
Old 09-30-2017, 06:00 AM   #16
Rewards Points: 552
Re: Finish Basement Wall Ideas... Help
Clean out plug, shut off valves, etc, would be framed 4 sides and covered with clean piece of plywood, sheetrock with edge trim or store bought access panels with cover. Make the access big enough, min 12x12".
If you don't want a wall over the pipes, you could:
1. xps on the foundation
2. 1x3 cleats on the xps with tapcon screws
3. drywall over the cleats
4. 3 sided box over the pipe and put your shelf over the box.
carpdad is offline   Reply With Quote
Old 09-30-2017, 06:18 AM   #17
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,530
Before you go to far, you'd be best to figure out exactly what the pipe is and if there is a possibility of re-routing it.
If it goes all the way around the basement, there must be a way to route it in a shorter run.
Can it be brought up higher to the ceiling, etc....
mark sr likes this.
Pugsy...my project: http://www.diychatroom.com/f49/total...storey-276978/
123pugsy is offline   Reply With Quote
Old 09-30-2017, 08:34 AM   #18
47_47's Avatar
Rewards Points: 320
Op, did you test for moisture yet?
Your basement is wide open. Where does the high side of the 4" line go? What room is above it? Follow the pipe to its lowest point and where does it lead? Take some pictures of the high and low end of the pipe.
123pugsy likes this.
47_47 is offline   Reply With Quote
Old 09-30-2017, 08:53 AM   #19
Rewards Points: 1,602
First, put your ear to the pipe and have Ms. Pinterest go around the house flushing toilets and running faucets/showers while you listen. Maybe you could be on the phone with her.
Then report back and post pictures of the entire pipe run from as far away as you can. I mean from beginning to end.
mikegp is offline   Reply With Quote
Tags
build , finish basement , walls
Basement half wall tekmonkey Building & Construction 1 12-24-2015 11:51 AM
Basement Ext Wall - Will Rigid Insulation allow my wall to dry inward? COLORADOMTNMAN Insulation 10 01-15-2012 11:09 PM
Finishing Basement Wall - Stairs Along Concrete Rob1976 General DIY Discussions 5 02-02-2011 09:39 AM
Thoughts and ideas basement finishing and HVAC creamaster HVAC 1 03-10-2010 08:46 PM
Will water lines freeze if placed behind insulated stud wall in basement? jpsmith Remodeling 22 03-05-2009 01:23 PM
