Finding That Elusive Stud - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-05-2013, 11:09 AM   #1
Finding that elusive stud
The pic is a exterior wall with stucco, the measurement starts on a outside corner. Note the nail holes along the tape measure. I have a zircon i65 stud finder that gave erratic results, tried with cardboard but results were the same. House built in 1951. So where in the heck are them studs!!
skyvok is offline   Reply With Quote
Old 12-05-2013, 12:48 PM   #2
Don't think the attachment worked.
Old 12-05-2013, 01:03 PM   #3
kwikfishron's Avatar
Rewards Points: 68
Any electrical outlets on that wall (either side)? If so there should be a stud just to the left side of the box. Find that and then just pull layout off of it. Or, bend and stick a piece of tie wire or something what seems to be a big hole in the wall at about the 10 3/8" mark and poke around until you find it.
kwikfishron is online now   Reply With Quote
Old 12-05-2013, 01:35 PM   #4
Yeah there is a outlet on the interior wall - measurement was 51" so I added 6" to outside measurement but no studs found. I will try the wire method tonight
Old 12-05-2013, 01:37 PM   #5
BTW are you able to view the pics? I can't see them after posting them.
Old 12-05-2013, 02:57 PM   #6
Newbie Bill
Rewards Points: 534
I can see them.
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Old 12-05-2013, 03:34 PM   #7
JOATMON
ddawg16's Avatar
Rewards Points: 10,042
Don't forget the fact that your stucco is about 1" thick...
Instead of drilling holes in the stucco...I would go inside....assuming your house was built like mine and has plaster walls...
1" for plaster.
3.5" for stud
1" for stucco
So...from the inside...a stud finder should find the stud...confirm with a small drill bit.
Once you have that...measure to the corner....add 5.5" to it....go outside...and measure from the corner...that should put you right on top of it.
One last thing....while your studs are 'supposed' to be 16" OC, not always the case....but usually is...most of the time...hopefully....but not always.....
ddawg16 is online now   Reply With Quote
Old 12-09-2013, 01:11 AM   #8
Stud finder never gave me reliable results - even the inside. The inside walls are composed of a inner layer of a felt like material about 5/8" and covered with 1/4" plaster - I am guessing that felt is the stud finders nemesis. So I had to use the nail method which worked.
Finding stud bay with plywood over the top plate Shiseiji Building & Construction 1 08-19-2012 03:27 PM
Finding elusive "up pipes" jackofmany Landscaping & Lawn Care 5 09-11-2010 04:32 PM
Moving a Stud HooKooDooKu Building & Construction 5 02-23-2010 02:11 AM
Stud Finding on Plaster and Lathe? Scotsman General DIY Discussions 9 12-06-2009 05:11 AM
Finding AC wires with Ryobi stud finder darsunt Tools 4 03-21-2007 08:43 PM
