Filling Joint Countertop - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-23-2010, 12:23 PM   #1
Filling joint countertop
Hi guys
The attached picture shows two countertops joined together. Unfortunately, there is a wider gap than usual in this case. About 1/32".
Is there anything I can do to make it "flush" and eliminate the apparent hole and black line? Fill it with some product that would work well in this situation?
Thanks!
GabrielB is offline   Reply With Quote
Old 08-23-2010, 02:03 PM   #2
jlhaslip's Avatar
Rewards Points: 708
there is a product for such a thing. can't remember the name...
you will need to find a local supplier of the laminate and ask them for a repair kit. not HD or Lowes...
it is plastic in a tube and is very 'hot' stuff. hardens very quickly.
tape off the joint, fill with the plastic stuff and then wipe it down with the thinner to clean it up and level it.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 08-23-2010, 08:26 PM   #3
yeh take it apart at seam or cut, it sand joints with belt sander for desired fit
even granite counter top people get better than that before they fill seam with coloured epoxy, which layman can't purchase
william4stairs is offline   Reply With Quote
Old 08-25-2010, 11:14 PM   #4
I have different kinds of epoxy. Couldn't I do take some colorant and put that in the mix to a make home-made "filler"? I believe water-based stain or a no-binder colorant would work? But oil-based is not compatible with epoxy I think right?
Would adding these standard pigments compromise the properties of the glue?
And more importantly, would the epoxy fit OK with the laminate counter top?
Or I'm gonna try to find what product jlhaslip was talking about.
Anyone knows?
Old 08-26-2010, 03:03 AM   #5
good luck w/epoxy it won't hurt anything but color matching isn't gonna be easy
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 12:20 PM
How to install countertop over washer and dryer R V Dunai Remodeling 13 08-21-2011 02:07 PM
butt joint pre-fab laminate countertop mrennolds Kitchen & Bath Remodeling 3 07-04-2010 11:34 PM
receptable inside cabinet DIYGST Electrical 8 01-29-2010 07:05 PM
Joint compound to smooth old paint layers. gmhut Painting 1 05-03-2009 05:50 PM
