Filling Hole In Slab - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-11-2009, 04:50 PM   #1
Landlord
Rewards Points: 89
Filling hole in slab
I have a hole in the slab foundation of my house. It is only about 3 inches down and 9 inches wide. Do I just fill it with Quickcrete and thats it? Thank you
cocean is offline   Reply With Quote
Old 06-12-2009, 05:35 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 2
Ayuh,... That's It...
Old 06-12-2009, 06:21 AM   #3
If possible, put a piece of plywood on one side as a backer. Run some tapcon screws or similar half way in, all around the opening. This gives something for the mix to hold on to. Make the mix very dry so it won't run all over the place.
Old 06-12-2009, 06:33 AM   #4
Hydraulic cement may work better.
jerryh3 is offline   Reply With Quote
Old 06-12-2009, 08:33 AM   #5
Landlord
Rewards Points: 89
Thanks for the answers. So I don't have to wet the concrete first or anything like that. Just put in the new cement and that's it?
Old 06-12-2009, 09:36 AM   #6
Civil Engineer
Rewards Points: 5,246
Assuming this is just a cosmetic repair (you don't plan to put heavy load above the patch), it is a simple matter of cleaning the hole by brushing to remove loose debris, mix up the concrete, place. I agree with the post about mixing it up dry, much stronger, less likely to crack. I would not be too concerned about bonding to the existing concrete, assuming this is a cosmetic fix rather than structural.
I would avoid hydraulic cement, costs more, sets very quickly, no aggregate, so is not as strong as normal concrete.
How to cut a hole in a concrete floor slab tomseeley General DIY Discussions 7 06-10-2009 02:32 PM
Filling a Chipmunk Burrow Hole handy man88 Landscaping & Lawn Care 1 09-08-2008 02:26 PM
Filling a huge stump hole moneymgmt Landscaping & Lawn Care 2 11-28-2007 12:34 PM
Filling hole in carport (concrete slab) chaddihimself Building & Construction 2 08-10-2007 12:50 PM
Sink hole under garage slab. diggitydog Building & Construction 3 08-31-2006 12:49 PM
