Fill In The Blanks - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-25-2009, 12:06 PM   #1
the Musigician
DangerMouse's Avatar
fill in the blanks
the framed-in rough width for a 36" entry door and casement should be _____".
the height should be ____".
there should be ___ stud(s) on either side of the door casement.
DM
Old 05-25-2009, 12:16 PM   #2
HABSFAN2006's Avatar
Rewards Points: 150
Originally Posted by DangerMouse View Post
the framed-in rough width for a 36" entry door and casement should be _37.5?____".
the height should be _81.5?___".
there should be _2_min._ stud(s) on either side of the door casement.
DM
Life is an experience... Learn from it!
HABSFAN2006 is offline   Reply With Quote
Old 05-25-2009, 12:26 PM   #3
Concrete & Masonry
Rewards Points: 534
38 1/4" wide, 82" high, 2 studs (shoulder & king) minimum, but I'm no carpenter.
jomama45 is offline   Reply With Quote
Old 05-25-2009, 01:13 PM   #4
Old School
Willie T's Avatar
All answers are "2"...... for any door except perhaps entry doors with very thick frames.
2" over door width
2" over door height
2 studs to each side.
Almost 2 easy, eh?
Admittedly, I make sure if I do error, it's a quarter or so on the bigger side.
But never make the mistake of thinking "one size fits all". This kind of lazy thinking will invariably come back to bite you in the arse.
One of my most difficult tasks (since I did mostly custom homes) was getting it pounded into my foremen and super's heads that they will never just frame for "standard" anything. The prints come with measurements and specifications clearly spelled out for a reason. That reason is that they are to ALL be read and understood before attempting any construction.
This day and age, nothing should be considered "standard"... at least not in my world of customs.
Willie T
Old 05-25-2009, 01:22 PM   #5
the Musigician
that's what i said too willie, 38"x82" and 2 studs. i was HOPING someone would agree with ME! lol
although, now my friend can see how different answers can be here too!
tnkx to all ....so far....
DM
Would you spring to fill in your backyard? Piedmont Landscaping & Lawn Care 4 05-14-2009 08:14 PM
Building a shed, need help with pouring slab / fill ssybert Building & Construction 5 06-12-2008 06:19 AM
cinder bloc shed - fill or no fill ? amakarevic Building & Construction 3 04-16-2008 09:07 PM
