Few Additional Question Blueboard/insualtion/etc - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-11-2010, 08:32 AM   #1
Rewards Points: 93
Few Additional Question blueboard/insualtion/etc
Hi,
I have a couple more questions as I get ready for the next phase. I had spray foam insulation sprayed on the ceiling and just got the inspection done. The sprayers stayed about a foot shy of the chimney. They said to fill that space with regular fiberglass (no papaer faced) Is there anything else I should do with that space? Or just fill with batts? DO I need to put poly over it? Or no because it is so small of a space. The rest of the ceiling does not need a vapor barrier but I am curious about those section.
Also, so I am getting ready for the walls to go up. I am hanging blueboard and then having it plastered. Is there anything different I should know hanging blue board as opposed to regular drywall? IE spaces/gaps/screws/etc. Or does it hang exactly like drywall. Keeping everything tight and so forth?
Getting down to the wire. Thanks in advance!!!
bfan781 is offline   Reply With Quote
Old 06-12-2010, 10:53 AM   #2
Rewards Points: 93
Anyone have any advice? Looking to start this tomorrow and want to be on the right track. Any input is so apprieciated
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 08:24 PM
Question about Supporting My Deck. . . bochamps Building & Construction 12 05-30-2009 07:57 PM
A question about water preassure. reasonforseason Plumbing 5 04-14-2009 04:36 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
hrv question indep HVAC 3 07-17-2008 10:39 PM
