Exterior Sheating - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree6Likes
  • 3 Post By kwikfishron
  • 1 Post By MTN REMODEL LLC
  • 2 Post By kwikfishron
Old 03-28-2017, 10:17 AM   #1
exterior sheating
Hello,
First post to this forum, I'm getting ready to reside my house cause it 20yrs old and going a diffrent color..while taking it off I found out I have the sturdy r board foam insulation and have no osb/plywood behind it...my ? Is should I take that down and put up plywood and then tyvex paper or just leave as is and put tyvex paper on top of it like I have been suggested to do by a carpenter friend..thanks in advanced for any suggestions.
Robert
Tracyrobert is offline   Reply With Quote
Old 03-28-2017, 11:24 AM   #2
jlhaslip's Avatar
Rewards Points: 708
Re: exterior sheating
Where are you located?
Unless you need the sheathing as per building code for a Shear Wall, simply Tyvek and residing would be good. Nail into the studs, obviously.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 03-28-2017, 11:30 AM   #3
Thanks for responding..located in Northwest I'll by Moline
Old 03-28-2017, 03:29 PM   #4
Registered User
Rewards Points: 526
----------Welcome to the forums!-------------------
What type of siding is on there now?
Is there OSB/plywood/other at the corners as required per codes to resist 90mph winds? pp. 15/109--------------- pp.34/109; http://www.ce.udel.edu/courses/CIEG4...%20-%20IBC.pdf
Gary
Old 03-28-2017, 05:13 PM   #5
Hi gary,
It has d4 siding on it now..I plan on redoing it with premium d4 siding. As far as the corners I'm not sure. I haven't gotten that far..I only taken of a piece to see what was behind it and seen it had foamboard..I took a 2 and a half in nail and pushed it through to see if it had plywood behind it and I got nothing..I read where builders use it instead of osb because it's cheaper and gives a higher r value..I had no idea that sturdy board was all he used when we bought house.
Robert
Old 03-28-2017, 05:23 PM   #6
Sorry,.I meant it gas viynl d4 siding
Old 03-28-2017, 06:26 PM   #7
kwikfishron's Avatar
Rewards Points: 182
Personally, I'd never want a home without wood sheathing.
The thought of vinyl siding, insulation and Sheetrock being my only protection from mother nature's wrath, flying projectiles and whatnot is not what I want my kids growing up in.
Not to mention the fact that I could break into your house while not making noise using no more than a utility knife.
I'll take the plywood thank you.
47_47, Bondo and Yodaman like this.
kwikfishron is offline   Reply With Quote
Old 03-28-2017, 07:37 PM   #8
Master General ReEngineer
Bondo's Avatar
Rewards Points: 264
Personally, I'd never want a home without sheathing.
Ayuh,.... I grew up in Maine, 'n always lived in the Northeast,....
1st time I saw houses bein' built, Without sheathing was in the '80s, in the southwest mid-west somewhere,....
It Blew me Away, never heard of such a thing,....
The load of plywood I brought there musta been for the roofs,....
When I got home, I asked friends,... Was told it's done in other places,...
We're still usin' sheathing up here,.....
Old 03-28-2017, 09:24 PM   #9
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 784
Pretty common for production bldg in Colorado.
Strange... no real reason... but I feel like KWIK... just doesn't feel right with cardboard or polysomethigchit for a wall.
But, it is fine structurally if shear walls are appropriate.
And a heck of a lot easier to sheath.
Bondo likes this.
MTN REMODEL LLC is offline   Reply With Quote
Old 03-28-2017, 09:42 PM   #10
Rewards Points: 182
Strange... no real reason... .
Especially when the sheet of foam cost as much or more than a 7/16 osb.
Bondo and MTN REMODEL LLC like this.
