Exterior Balloon Framed Wall, Adding A Header For An Addition - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 1 Post By Nealtw
  • 1 Post By Fisher1871
Old 07-19-2018, 01:03 PM   #1
Rewards Points: 416
Exterior balloon framed wall, adding a header for an addition
I tried to be as descriptive as possible in the title, but a picture may help.
This is an old fashioned balloon framed home. The exterior wall studs run from the sill plate (below what can be seen in photo) all the way to the top plate where the rafters rest. The 2x4s are probably 22-24ft in total length.
This photo is of the kitchen. I would like to add a small addition protruding beyond the wall in the photo, thereby enlarging the kitchen. The addition will run the entire length of the house, but a header will only need installed where I remove the wall (in picture) to enlarge the kitchen.
I can envision how I would support the floor joists for the second floor in this project, but how the heck would I support the 2x4s (once cut) that make up the 2nd floor exterior wall and support the roof?
Fisher1871 is offline   Reply With Quote
Old 07-19-2018, 01:54 PM   #2
retired framer
Rewards Points: 6,226
Re: Exterior balloon framed wall, adding a header for an addition
Up stairs do a temp header with 2 2x10 screwed to the studs one above the other 4 screws into each stud. Hold up floor with temp wall remove the board the joist sit on and cut in your new header, at least 2 jack studs on each side all the way down.
A 2 ply 2x10 header will be really close to over loaded, You may want to go with LVLs
MTN REMODEL LLC likes this.
The Following User Says Thank You to Nealtw For This Useful Post:
Fisher1871 (07-19-2018)
Old 07-19-2018, 02:41 PM   #3
Rewards Points: 416
Great explanation! So dang simple when you lay it out.
Definitely plan on going with LVLs.
Nealtw likes this.
Old 07-19-2018, 02:44 PM   #4
retired framer
Then don't forget the fire stopping between floors and from the wall to the floor structure.
Old 07-19-2018, 02:49 PM   #5
Rewards Points: 416
That's next on my list after I complete the wiring.
Nealtw likes this.
Multi Level Stem Wall Addition Jwlerza2 Building & Construction 7 06-26-2018 01:18 AM
Installing framed bathtub shower doors on bowed wall? spinnaker15136 General DIY Discussions 2 12-10-2016 02:57 PM
Blind header above removed interior wall adam83 Building & Construction 6 11-28-2016 03:54 PM
Updating Timber & Balloon Framed Home (LONG POST) Pittsville Building & Construction 13 05-29-2013 01:15 PM
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 04:11 PM
