Extension - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-04-2009, 02:48 PM   #1
edd
extension
hi, i have a brick built shed 1 meter from my back door, it runs along the line of the side of the house.
i would like to use the sheds outer walls and extend out to the shed. given the shed is a permanent structure do i need planning permission for this extension or can i get round it??
edd is offline   Reply With Quote
Old 07-04-2009, 08:55 PM   #2
You want to use the sheds outer walls & extend out to "the shed" ??
Extend out to a 2nd shed?
Is this near the property line?
Where are you located?
How big is the shed & how much are you adding on?
Old 07-05-2009, 08:44 AM   #3
If I read your question right, you are proposing to connect the shed to your house. This in effect chages it from an "outbuilding " to part of the home.
Best place for an answer, your municipal building department.
GerryinBelleRiv is offline   Reply With Quote
extension cord draining power? mt232 Electrical 14 05-25-2011 03:37 PM
help re-installing shower head 1/2" pipe extension cbons Plumbing 2 04-15-2009 05:06 PM
Extension Cord Safety Ultrarunner2017 Electrical 23 01-20-2009 09:11 PM
Concrete Patio Extension redhermes Building & Construction 14 11-18-2008 10:09 PM
Air Compressor stopped working, extension cord was used. dawho1 Tools 3 10-07-2008 05:14 AM
