Extending An Already Extended Closet Into A Garage - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-04-2016, 04:57 AM   #1
Rewards Points: 2
Extending an already extended closet into a garage
Hello all,
The master in our house came with a 5 ft wide by 2 ft deep closet that was built into the garage, having a master with a closet must have been an afterthought (along with a lot of things...). I want to extend it another 4 or so feet into the garage as my wife is pregnant and the room we were using as a dressing room is going to be the nursery.
Right now the closet is floating into the garage. The house is a wide ranch and the floor level is approx 2 feet above the garage (grade) floor. I assume they just extended joists out and framed it. The basement does not extend into the garage but the room side I cannot see where they attached the joists or whatever is supporting the floor. Right now its just floating in the garage, I assume they must have anchored it to the adjoining outer wall.
I'm sure I'm going to find some nutty stuff when I open it, my question is, what is the best way to secure it to the garage floor? I was thinking cinder-blocks and concrete fill. That's a simple L but how would I attach it to the garage floor, I was thinking drilling down the block voids into the floor and putting some rebar in before I filled the block.
I don't want to do posts, being the garage I'd feel safer knowing the support was solid and not something that could be "kicked" out or tapped by a car.
Any suggestions would be great. Thanks in advance.
WAstarita is offline   Reply With Quote
Old 04-04-2016, 07:04 AM   #2
Retired Moderator
Rewards Points: 7,174
Re: Extending an already extended closet into a garage
Your block idea will work---however, garage slabs 'float' and there is a small possibility that the slab will lift or sink with the seasons.
You could take a chance of cracking drywall or cut out the slab and add a footing for the block work.
Your call---
Converted garage to bedroom while garage door still intact. Sealing wall opening. calleros24 Building & Construction 9 11-01-2014 07:00 PM
70s Garage door becoming heavy, comes down faster on right than left. mguise Windows and Doors 13 07-10-2014 03:00 PM
Weatherproofing garage help Perfik Building & Construction 2 10-17-2012 04:30 PM
Laundry closet decision LClark Remodeling 2 06-26-2011 07:19 AM
Raising up my garage jimmyfloyd Building & Construction 5 09-17-2009 11:39 PM
