Expanding Under Home Garage - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-29-2014, 10:18 AM   #1
Rewards Points: 2
I have an existing one car under home garage (~10'x15') that I would like to consider expanding lengthwise (i.e. to ~10'x30').
The home is situated on a raised hill, meaning that the driveway is flat leading into the garage from the street with retaining walls on either side. My question is whether building codes, which typically require new garage construction to be >6' from existing structures, would allow for such an addition.
If building codes allowed, the project would progress generally as follows: 1) demolish existing retaining walls on either side of driveway, 2) demolish existing asphalt driveway, 3) pour new garage foundation, 4) pour new garage walls in place of retaining walls, connecting to existing garage walls, 5) backfill, 6) construct garage roof and install new door.
Does this sound feasible?
Garage Help is offline   Reply With Quote
Old 10-29-2014, 10:34 AM   #2
Rewards Points: 626
given enough money yep!
Nailbags is offline   Reply With Quote
Old 10-29-2014, 10:56 AM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 17,684
We need pics....and you need to go have a chat with your building dept.
Don't be afraid of them. If you go in asking what is possible (take pics with you), I think you will be surprised at how much they will help and time you will save getting bad info.
It also helps to put your location in your profile.
Now, if you want to see a 'real' garage....click on the link in my signature.
Tags
addition , building code , expansion , foundation , garage
Garage door water barrier eharri3 Building & Construction 3 01-14-2014 09:01 AM
Need URGENT help with question regarding fixing electrical panel in home asledge Electrical 66 02-22-2013 05:49 PM
Attaching my garage to my home Schofieldfam Building & Construction 3 09-25-2012 09:17 AM
Garage Insulation yamster Insulation 0 07-01-2011 02:30 PM
Vacation Home garage conversion imgarret Remodeling 0 01-30-2010 09:15 AM
