Estimate Blown Insulation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-07-2011, 07:43 PM   #1
Estimate blown insulation
How do I figure out LxWxH or Sf X Height??? Thank Mark
markdarto is offline   Reply With Quote
Old 01-08-2011, 07:43 AM   #2
Rewards Points: 506
Cubic feet? Not really sure what you're asking.
jlmran is offline   Reply With Quote
Old 01-08-2011, 07:55 AM   #3
Experienced
Jackofall1's Avatar
Rewards Points: 2,126
Either one of the calcs you show will result in cubic feet.
Old 01-08-2011, 08:27 AM   #4
Retired Moderator
Rewards Points: 7,174
Give us your actual numbers---
Old 01-08-2011, 09:06 AM   #5
Rewards Points: 506
This is not meant to be a sarcastic answer...just not sure what is asked. use a tape measure to measure the area to be insulated (L and W). Then determine how thick (H) the insulation is to be. Is this for walls or ceiling?
Old 01-08-2011, 10:26 AM   #6
Rewards Points: 2,650
Try:
http://www.lowes.com/cd_Blown+Insula...tor_619120107_
bob22 is offline   Reply With Quote
Old 01-08-2011, 10:48 AM   #7
Mr Fix it!
yes that link will work, you can also easily dpo the math on you phone right in the store using the chart on the back of the bag. It's pretty easily based on the sq feet of your house.
home-restore is offline   Reply With Quote
Old 01-08-2011, 12:15 PM   #8
Registered User
Rewards Points: 526
Depends on the installed density (weight per cubic foot), you need higher than 0.50 per cubic ft. or it will have convective loops; http://www.diychatroom.com/f98/how-b...ulation-90438/
Gary
Old 01-08-2011, 02:31 PM   #9
Rewards Points: 506
Markdarto appears to be Markdissapearo.
Recently Topped Up Attic with Blown Insulation...Now I have Frost/Condensation earthad1 Building & Construction 81 02-18-2011 12:42 PM
Has anyone used Green Fiber blown in insulation? pomelo Building & Construction 7 02-10-2010 07:17 AM
Flat Roof and Blown Insulation... inlikeflint Building & Construction 4 01-26-2010 12:42 PM
Blown insulation Xtreme_99 General DIY Discussions 1 01-05-2009 05:56 AM
old blown insulation djknob Building & Construction 3 12-29-2008 11:20 AM
