Eight Month Old Deck Issues - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree4Likes
Old 07-21-2018, 11:44 AM   #1
Rewards Points: 26
Eight month old deck issues
My deck was completed around the end of November, 2017. I travel a lot, so I have not spent time using the deck. It wasn't until I was attempting to get it stained about two weeks ago that the issues in the picture where brought to my attention and described as poor craftmanship. My deck is still under a warranty. I assume all the wood used to build my deck was pressured treated. Installers told me to let the deck dry out and stain within 6 to 12 months following the install. I'm really concerned about construction, stability, and safety in the long term. Do these pictures reflect normal shrinkage of pressure treated wood within eight months of installation, gaps and wood bowing?
Eight month old deck issues-img_2018.jpg   Eight month old deck issues-img_2021.jpg   Eight month old deck issues-img_2023.jpg   Eight month old deck issues-img_2091.jpg   Eight month old deck issues-img_2019.jpg
Mgerald55 is offline   Reply With Quote
Old 07-21-2018, 11:53 AM   #2
retired framer
Rewards Points: 14,016
Re: Eight month old deck issues
We will want to see how the deck meets the siding of the house.
How the structure is attached to the house and beams down stairs.
He might be able to re cut the corners and just move the boards in a little and re use them.
de-nagorg likes this.
The Following User Says Thank You to Nealtw For This Useful Post:
Mgerald55 (07-23-2018)
Old 07-21-2018, 12:02 PM   #3
JUSTA MEMBER
Rewards Points: 2,398
PT will shrink, and warp, bow and twist.
Especially if it is wet when installing, normal, but a decent installer will repair those faults that you show under warranty, but get them informed right away, or lose the warranty.
How is it attached to the house, and how sound is the basic structure foundation.
posts in concrete footers to the frostline, beams affixed solidly, etc.
ED
de-nagorg is offline   Reply With Quote
Old 07-21-2018, 07:07 PM   #4
Rewards Points: 17,808
The first picture is the most troublesome.
He built it upside down
I learned long ago that the only way to keep those top rails at the 45 to keep from opening up is to let them lay out in the sun for a week spreaded out so they can start to dry out before installing.
If there's money in the budget I use composite decking for the top rail so the joint is tight and there's no more cupping, checking issues, and can be done so there's no exposed screws on the top of the railing..
The ones in your picture where cut at the wrong angle in the first place, that's why it's wider on one end.
The wide decking spacing is likely caused because they spaced it out to begin with, which is not needed, as it shrinks there would have been gaps even if they installed them tight.
Gymschu likes this.
Old 07-21-2018, 08:06 PM   #5
Rewards Points: 1,728
Outdoor miters that wide will always move around, might be able to cut them and rescrew depending what's on the other end. Could also just put a block on top of them and put a solar light there.
The look down at the railing is normal shrinkage.
As others point out, these issues are not structural, but how does the main ledger look, and the beams, and what were the posts set into?
ChuckF. is offline   Reply With Quote
The Following User Says Thank You to ChuckF. For This Useful Post:
Old 07-21-2018, 09:33 PM   #6
Rewards Points: 1,502
That beam close to the house suggests its freestanding?
Id go with the block and light idea...
ryansdiydad is offline   Reply With Quote
The Following User Says Thank You to ryansdiydad For This Useful Post:
Old 07-22-2018, 10:05 PM   #7
Msradell's Avatar
Rewards Points: 740
There is also a line of posts along the house side of the deck. Another sign that it's freestanding.
Nealtw likes this.
Written using Dragon Naturally Speaking
Msradell is offline   Reply With Quote
Old 07-23-2018, 06:42 AM   #8
Rewards Points: 26
Thank you. I've added more picture in an album.
Old 07-23-2018, 06:44 AM   #9
Rewards Points: 26
Thanks for rotating my picture
Old 07-23-2018, 06:50 AM   #10
Rewards Points: 26
Thanks for your post. Deck is attached to the house. There is a layer of wood covering a damaged area of the house from where an old deck was previously located.
Old 07-23-2018, 06:56 AM   #11
Rewards Points: 26
Deck attached to the house. I saw concrete was apart of the construction materials. I didn't see the deck post installation. I did notice the lower step base was built on top of harden concrete.
Old 07-23-2018, 07:04 AM   #12
retired framer
Can we have a close up at this , is there flashing below the deck that is visible from below
Old 07-23-2018, 07:07 AM   #13
retired framer
If there is wood behind this the needed to be flashing.
Old 07-23-2018, 07:11 AM   #14
Rewards Points: 26
LOL! Crazy deck pics.
Old 07-23-2018, 07:12 AM   #15
Rewards Points: 26
Can the bowing be corrected?
Cedar deck help mickbiv Painting 11 08-08-2013 09:21 PM
Surface Mounted Deck Post Problem sore thumb Building & Construction 17 04-06-2013 05:45 PM
foundation walls to support a deck bubbler Building & Construction 1 04-12-2012 03:27 PM
Pergola over existing deck cpfullback Building & Construction 0 08-04-2011 11:36 AM
Please Help! Deck Issues llcooljayce Building & Construction 21 06-30-2007 09:27 AM
