Egress Window, Structurally Safe? - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-20-2011, 07:38 PM   #16
Registered User
Rewards Points: 526
Four years ago in a addition egress window, the casement opened out on the one side, as normal, but the hinge side came back into the opening 4", so the radius opening would be greater. I contacted the rep, who said it was rated as egress, ............ sent two complete new replacement windows, 6*5*. Had already lap sided them, second floor.....man.... light bulb went on upstairs..... replaced only the casement hardware on the tops and bottoms which was a different opening radius on the new windows. Notified the manufacturer, said this was the first complaint in 1-1/2 years ago since changing to the new (non-compliant) hardware. Check everything......
Gary
egress window terrytoo Building & Construction 3 11-11-2010 06:47 AM
egress window kikipauw Building & Construction 3 11-10-2010 07:30 AM
Bathroom window issues? Mantaray14 Remodeling 11 12-04-2009 08:40 PM
Egress Window Questions? cibula11 Building & Construction 12 03-15-2007 01:24 PM
Gun Safe vs. Floor Joists allen1466 Building & Construction 9 03-03-2006 09:16 AM
