Easement Issues With Gas Co? - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-09-2013, 03:33 PM   #16
Rewards Points: 304
Just thought of another possibility: typically the easments along property lines are intended for local service utilities. The line you hav obviously is a larger transmission line. It may have a sepeate easement that was taken at a different time, and the title company missed this seperate easement.
Good luck with this. Have you consideder a shed that is small enough to not need a permit? If that's allowed in your area that might avoid the whole issue entirely. It could be built on PT skids, or on non-permanent footings, and be not be considered "permenent" . Tou can do that in my area and put it in an easement. Worst case is the utility needs to work in the easement and the shed needs to get moved. Not ideal, but might be practcal.
A Squared is offline   Reply With Quote
temperature and pressure issues jpa137 Plumbing 7 04-04-2012 10:48 PM
House settling issues gmvshort Building & Construction 3 02-22-2011 07:26 AM
Demo'd Half-Bath, Issues, Pics Attached, Have at it... 99altrade Building & Construction 4 12-21-2010 05:50 PM
Spray foam - code issues? upinsmoke Building & Construction 1 05-10-2010 08:47 PM
