Drywall And Trim Issue, Need Help Please - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-03-2015, 12:22 AM   #1
Rewards Points: 54
Drywall and Trim issue, need help please
I'm working on a older home and I'm going to replace the drywall and trim/casing in a hallway. The problem I'm having is someone added drywall and trim at a later date and did an amateur job. The baseboards and door casing are almost flush with the dry wall and looks tacky. (This is an older home and most likely had wall paper originally.) My question is, what is the best way to add new trim and have it sit on top of drywall like its suppose to, rather than flush with it. Now if I add 1/2" drywall, and place trim on top of it that will fix it, but would leave raw drywall edge around door frame how do you guys usually address this? Thanks
will04 is offline   Reply With Quote
Old 09-03-2015, 03:16 AM   #2
Rewards Points: 144
Remove the door casing.Add the new drywall and then attach some jam extensions to the jambs to bring them out flush with the face of the new drywall.
mako1 is offline   Reply With Quote
Old 09-03-2015, 06:09 AM   #3
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,438
Me, I would probably "lose it" and rip it all out. Hack work gets my fire boiling.
I can see waves in the photo and I'd bet it's like that throughout.
Pugsy...my project: http://www.diychatroom.com/f49/total...storey-276978/
123pugsy is offline   Reply With Quote
Old 09-03-2015, 12:49 PM   #4
Rewards Points: 54
Yes I'm going to rip all drywall and trim out in the hallway and go back with all new. The trim doesn't even match the trim in the rest of the house, so i'll have to duplicate it. Actually the rest of the house still has original trim and looks good.
The Following User Says Thank You to will04 For This Useful Post:
123pugsy (09-03-2015)
Old 09-03-2015, 01:01 PM   #5
123pugsy's Avatar
Post some pics of your progress. Would love to see the results.
Old 09-03-2015, 01:04 PM   #6
Rewards Points: 948
You might have more than one layer of drywall. I would remove the casing around one door to see what your dealing with, and then post photos if necessary. The jamb dimension will need to match the finished wall dimension--and that can be done when recasing the door.
Generally, decide on the appearance of the casing you want--most likely to match what is done elsewhere in the house. Remove drywall in the areas where it doesn't look right and re-drywall. Be sure everything is plumb and square, use the appropriate corner beads, etc. Rebuild the casings to match. Once the drywall is redone, the casing situation should be clear.
keymaster is offline   Reply With Quote
The Following User Says Thank You to keymaster For This Useful Post:
will04 (09-03-2015)
Old 09-03-2015, 04:01 PM   #7
Rewards Points: 4,796
Keymaster beat me to it concerning the drywall. You see this a lot in older homes that were used for rental properties. If this is the case do yourself a favor and also check out all the floors, ceilings, etc..
I've seen where floors were laying on the ground with another floor built right on top of it. Floors that sagged up to 1 foot and they just used plywood to level it out. Double walls that revealed another space. I had one call where a second floor collapsed because of all the weight, balloon structure houses are really known for this.
You never know......
ron45 is offline   Reply With Quote
Old 09-03-2015, 04:41 PM   #8
Rewards Points: 54
This was a 3 owner home built circa 1925. Still has original hardwoods on first and second floor and other than the hallway here everything else appears original and untouched. Although there are areas that will need leveling.
Old 09-03-2015, 04:52 PM   #9
Mad Scientist
That is some of the worst drywall hackery I've ever seen, with the possible exception of the last flip I worked on, with 4 layers of assorted ceiling material in the living room.
I'd definitely rip it all out; who knows how wrong it is underneath.
McSteve is offline   Reply With Quote
Old 09-03-2015, 05:44 PM   #10
Rewards Points: 948
The interior doors and hardware in the photo are great, and original (painted over, but still nice). Keep those. What does the other trim look like?
Old 09-03-2015, 06:15 PM   #11
Rewards Points: 54
I'm all about restoring, So ill save everything. I've put old painted hardware in crock-pots to remove layers of paint. There are glass door knobs throughout and a lot of original French doors as well as five panel doors.
Old 09-03-2015, 08:43 PM   #12
Rewards Points: 948
That's good to hear. The french doors and five panels look nice. Is it possible that some of the trim is original, and just looks bad because of the depth and installation of the drywall? Something to consider, anyway. It's unusual to have original doors and new trim.
will04 (09-03-2015)
Sealing gaps between new door trim & drywall stripedbass Drywall & Plaster 32 07-18-2015 12:56 AM
Trim old drywall resting on slab? Klawman Drywall & Plaster 8 07-04-2015 07:58 PM
Best way to seal gap in drywall around recessed lighting trim TangledUp Drywall & Plaster 10 06-19-2013 08:53 AM
Bathroom Remodel - Trim / Drywall Issue medic8106 Remodeling 7 09-29-2011 10:52 PM
Drywall instead of trim around window MP_777 Drywall & Plaster 12 02-09-2011 10:26 AM
