Drywall Corners - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-01-2011, 08:37 PM   #1
drywall corners
I am about to start drywalling and have a question. Where my edge of my ceiling drywall meets my wall (long edge), there is a gap of about 4 inches to the wall.I have read where you should float your corners and not attach the edge of the ceiling to the top plate. Should I just use the wall piece to support the ceiling piece or should i use scrap along the edge to give the ceiling edge a secure place to attach the edge? Help
mort5029 is offline   Reply With Quote
Old 02-02-2011, 06:39 AM   #2
Stay-at-home GC
Are there roof trusses above? I'm not a drywall pro, but I believe the reason not to attach your drywall at the ceiling corner is to prevent cracking when Truss Uplift occurs in the summer. It is most critical where the truss crosses above the center bearing wall.
Can correctly identify Shinola 3 out of 5 times*
*Under ideal conditions
Some days, my Life needs a Rewind/Erase Button.
CplDevilDog is offline   Reply With Quote
The Following User Says Thank You to CplDevilDog For This Useful Post:
Willie T (02-03-2011)
Old 02-02-2011, 08:04 AM   #3
There are floor trusses so I am not sure if I should attach, ok so it would probably safe either way not to attach at the corner?????? I guess if the wall board is supporting the ceiling it should be good?
Old 02-02-2011, 08:45 AM   #4
I'm also reading, if correctly, that I should never secure the drywall with screws closer that 8" form the edge. I am also reading that the wall board will support the ceiling and that there is less likely of cracks since there is room for movement.
Old 02-02-2011, 03:00 PM   #5
Drywall contractor
Rewards Points: 1,114
You can safely "float" a 4" span.....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 02-03-2011, 07:30 AM   #6
thanks blbatlanta thats the answer I was looking for
Old 02-03-2011, 08:21 AM   #7
Old School
Willie T's Avatar
Look into "drywall clips".
Willie T
Superior Walls - Floating Corners & Drywall Woodcutter Drywall & Plaster 16 04-22-2011 01:05 PM
drywall over old plaster... lcann25 Remodeling 0 09-21-2010 12:53 AM
Large drywall patches - best way to fix? Screw them to what? Scott99999 Drywall & Plaster 6 11-19-2009 05:34 PM
Corners with drywall? Ol' Luke Building & Construction 9 11-09-2006 07:17 AM
