Dryer Vent Through Brick - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-09-2010, 01:12 PM   #1
Rewards Points: 61
Dryer vent through brick
The hole I hammer-drilled through my upstairs brick wall is somewhat larger than the 4" diameter of the dryer vent. How do I finish the job so that it fits tight and looks clean?
gnikyerffej1 is offline   Reply With Quote
Old 04-09-2010, 01:22 PM   #2
fabrk8r
fabrk8r's Avatar
Make a metal escutcheon plate with an inside hole the same I.D. as your vent pipe and the outer diameter large enough to cover the rough opening.
If you don't have the tools or material just call a local heating shop and ask them to make one for you. I make alot of both stainless steel escutcheon plates and galvanized. I usually make the 2-piece because they are easier to put on if there is an elbow that you would have to slide a 1-piece plate over.
fabrk8r is offline   Reply With Quote
Old 04-09-2010, 01:33 PM   #3
Rewards Points: 61
And then affix the plate to the exterior brick using masonry screws, followed by caulking the edges to make it watertight?
Old 04-09-2010, 01:35 PM   #4
fabrk8r
fabrk8r's Avatar
Screw it if necessary. If you have a nice tight fit a good quality caulk, such as Vulkem, is usually enough to keep it in place.
Old 04-09-2010, 02:38 PM   #5
kwikfishron's Avatar
Rewards Points: 866
Make a cedar block just like for any siding job.
kwikfishron is online now   Reply With Quote
Tags
dryer vent brick wall
Dryer vent problem carguy4sp General DIY Discussions 7 11-29-2010 08:26 AM
Please look at this dryer vent installation Andy Griffith Appliances 6 08-31-2009 12:39 PM
very clogged dryer vent. Not just lint catman Tools 4 04-20-2009 04:48 PM
Dryer vent ponch37300 General DIY Discussions 10 01-21-2009 04:26 PM
Help, how & where can I vent a 2nd floor dryer? jaes Remodeling 2 06-28-2008 10:03 AM
