Drilling Through Block/brick - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-15-2016, 07:43 PM   #1
Rewards Points: 225
drilling through block/brick
Need to drill a 3" diameter hole through hollow block/brick wall. Bosch has a core bit and there are various size small diameter 12" sds bits to drill multiple holes and knock out waste. Would be using a rotary hammer drill 1 1/8" 8 amps. Not sure if this is enough for the core bit. Anyone try both methods? Preference? Thanks.
gt1935 is offline   Reply With Quote
Old 02-15-2016, 08:22 PM   #2
WhatRnsdownhill's Avatar
Rewards Points: 2,220
just take a small sledge and knock a hole in the block and trim it out with the bit in your hammer drill, then drill a few holes in a circle on the brick and chop out, ur done in no time...the core bits are more for poured concrete foundation..hollow block is weak..and brick will drill easy..
WhatRnsdownhill is offline   Reply With Quote
Old 02-15-2016, 10:44 PM   #3
JUSTA MEMBER
Rewards Points: 1,104
If you want a neatly drilled hole, get a diamond core bit, otherwise as Whatruns stated, just do it that way.
ED
de-nagorg is online now   Reply With Quote
Tips for drilling perfectly level holes in studs? eholmes77 Carpentry 16 10-07-2015 10:57 PM
Am I drilling into plaster and lathe? jespisa Drywall & Plaster 3 07-15-2012 09:01 PM
Drilling holes in concrete slab spaceman spif Building & Construction 12 10-18-2010 10:10 PM
Drilling asbestos siding (hanging shutters) MichaelDutch Remodeling 3 06-15-2010 11:49 AM
Help: Drilling into concrete or stud? rev1976 Building & Construction 7 05-11-2010 02:47 PM
