Drilling Out Screw - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-07-2009, 11:17 PM   #1
Unhappy
drilling out screw
Hi, I'm new and not having a good day.
I thought I would do a small job around the house and replace some outdoor light covers that were looking a little worse for wear. A simple job I thought! Anyway the first cover was a breeze the other four however have two screws in each that have corroded to the metal. I managed to remove some through various methods of heating, tapping and using a certain amount of force. However there are still 2 screws that the heads have come off of. I have been trying to drill out the centres but my drill bits just keep breaking. What am I doing wrong??
I would really appreciate any help you can give me before I'm forced to call in the electricians to remove the whole units. Many thanks.
Ohmy!! is offline   Reply With Quote
Old 09-08-2009, 06:14 AM   #2
If there is room enough, file/grind the screw flat, then center punch. start with a small bit, go slowly. And try some penetrating oil such as PB Blaster on the screw.
Do screw heads really need to be mudded with three coats? KUIPORNG Remodeling 33 09-17-2011 01:54 AM
Stuck Screw IceTreay General DIY Discussions 11 09-09-2010 01:56 PM
Can't get set screw in TP holder loose janralix Plumbing 4 08-12-2009 10:47 PM
