Drilling In Concrete Wall - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-03-2010, 06:09 PM   #16
Rewards Points: 392
Originally Posted by itsreallyconc View Post
concrete walls don't have any ' halo part of a block ',,, its not 'crete but a block wall as you sez,,, were you using a twist drill & carbide bit OR did you need a hammer drill ? twist masonary bits will drill block but a waste of time on conc,,, soon's your bit ' broke thru ', you shouldda realized it weren't 'crete,,, jomama can explain it more fully.
forget the apron stores - find the right anchor at ' fastenwal ' branch,,, failing that, find the mortar jnt & put your anchors there,,, hope you don't weigh too much, tho - no financial interest
Sorry, but I wouldn't trust anchoring into a mortar joint for something such as a pullup bar.
rustyjames is offline   Reply With Quote
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 6 05-19-2017 04:53 PM
Considerations when pouring concrete against a stucco wall? clint_nichols Building & Construction 9 09-24-2009 05:28 AM
what should I be careful about when drilling a hole through in the wall. foxwood Remodeling 3 08-25-2008 04:17 PM
Tight drilling angle fw2007 Electrical 8 05-31-2008 09:33 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
