Downset Beam - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-27-2016, 11:11 AM   #1
Rewards Points: 2
Downset Beam
What does the term Downset Beam mean and how used?
Tduff is offline   Reply With Quote
Old 12-27-2016, 12:04 PM   #2
Registered User
Rewards Points: 526
Re: Downset Beam
----------Welcome to the forums1--------------------
It is opposite an upset beam, pp 9; http://nhboa.net/wp-content/uploads/...guidelines.pdf
"Down" refers to it being installed below the joists. The joists resting ON it. There is also a "flush" beam...lol.https://www.google.com/search?q=flus...utf-8&oe=utf-8
Gary
Old 12-27-2016, 12:04 PM   #3
Rewards Points: 1,376
Re: Downset Beam
Did you mean downSTAND beam?
ront02769 is offline   Reply With Quote
Old 12-27-2016, 06:13 PM   #4
jlhaslip's Avatar
Rewards Points: 708
Re: Downset Beam
My preference is to call it a "Drop" Beam.
Joists rest on top of it, the Beam is dropped below the joists.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
The Following User Says Thank You to jlhaslip For This Useful Post:
Msradell (12-27-2016)
beam replacement and sistering Bamboozler Building & Construction 22 06-20-2016 12:01 PM
Flush Beam Install jeffa123 Building & Construction 4 07-20-2015 10:27 AM
L shaped porch framing onjtrainee Building & Construction 34 02-07-2015 07:10 PM
Column location for LVL Beam Perry401 Building & Construction 1 09-10-2013 11:27 PM
How to repair main support beam Jerry48ece Building & Construction 0 01-08-2011 08:38 PM
