Double Rim Joist - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-19-2009, 02:39 PM   #1
I have gas!
Clutchcargo's Avatar
Rewards Points: 2,046
Double Rim Joist
Is it a good idea to double the rim joist on the sides that run parallel with the joists or is it unnecessary?
I'm conflicted thinking that it's a good idea to transfer load but at the expense of 2" insulated foam.
I tear things down and build them up.
Clutchcargo is online now   Reply With Quote
Old 06-19-2009, 02:45 PM   #2
Rewards Points: 1,910
If the rim is sitting solidly on a sill plate that sits solidly on the concrete stem wall then I see no point to doubling the rim.
Old 06-19-2009, 08:12 PM   #3
Framing Contractor
No need at all to double for what you're talking about.
Joe Carola
Joe Carola is offline   Reply With Quote
floor joist issue drtbk4ever Building & Construction 4 03-22-2009 10:20 AM
sistering in a plumber whacked joist 4just1don Building & Construction 7 02-04-2009 01:33 PM
replacing rotted sill plate and rim joist behind a deck ledger board tommyt Building & Construction 2 08-11-2008 07:38 PM
Engineering help request: drilling holes in a deck joist, supported by a post Deck Building & Construction 14 05-31-2008 10:16 PM
Cutting/drilling hole in joist - How big? curls00 Carpentry 3 07-20-2007 09:56 PM
