Dormer Issue - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-17-2013, 08:37 PM   #1
dormer issue
Can someone please explain how to determine shed dormer headwall height?
markharmon is offline   Reply With Quote
Old 07-18-2013, 02:24 PM   #2
GBrackins's Avatar
Rewards Points: 2,108
depends on the height of the dormer wall, slope of the dormer shed roof and existing roof slope
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 07-18-2013, 03:46 PM   #3
Im asking how to determine the headwall height so why are you asking me for the wall height?
Old 07-18-2013, 03:47 PM   #4
dormer shed roof will be 7/12. The existing roof is the same.
Old 07-18-2013, 03:47 PM   #5
GBrackins's Avatar
are you putting a window in the dormer? what is the purpose of the dormer? how tall, how far above the floor is the window? how wide is the dormer? can you tell there are a lot of questions when it comes to dormers?
Gary
The Following User Says Thank You to GBrackins For This Useful Post:
woodworkbykirk (07-18-2013)
Old 07-18-2013, 09:05 PM   #6
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,578
you basically have to open up the existing roof and reinforce the sides of the opening. .then from there frame your front wall at the required height you want. for a proper window height.. then just frame the roof to that..
theres too many calculations that have to be done on site to do it over the internet
woodworkbykirk is offline   Reply With Quote
Old 07-18-2013, 09:27 PM   #7
GBrackins's Avatar
I think you need to take a closer look at your roof pitches. if both are framed with the same pitch and the dormer roof begins lower than than the existing ridge then your dormer roof will be under the existing roof.
now if you did a gable dormer you'd have something better to work with, at least in my opinion
good luck!
Gary
Old 07-18-2013, 11:25 PM   #8
when you add trimmers to the existing rafters do they extend from the ridge all the way to the exterior wall of the house or just to the bottom header?
Old 07-19-2013, 04:24 PM   #9
you have to double the existing rafters first from teh ridge to the plate as these rafters now compensate for a larger opening in hte roof
Old 07-21-2013, 10:35 AM   #10
AHH, SPANS!!!
Rewards Points: 1,166
dormer height needs to be no less than 7 1/2 foot from floor and woodworkbyKirk is correct, the rafter either side of the dormer need to be doubled or tripled or lvl,ed depending on the dormer size with an appropriate sized header across the doubled up rafters to catch the rafters above the dormer that are cut off from placing the dormer.
hand drive is offline   Reply With Quote
Number of Receptacles in a Dormer Alcove? chabot150 Electrical 8 01-09-2013 11:24 PM
Vent stack ruining dormer plans! joshnoiseux Plumbing 6 11-01-2012 12:04 PM
Why Leaking Roof under Dormer / hole in OSB!!! MB1 Roofing/Siding 32 12-15-2011 05:20 PM
Westinghouse furnace issue joe8918 HVAC 9 12-04-2011 06:50 PM
how to reduce mositure issue on basement? diy001 Building & Construction 0 10-28-2011 01:44 PM
