Door Rubbing Only In Winter - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-31-2009, 07:26 PM   #1
Rewards Points: 736
Door rubbing only in winter
I have a door going into my one room that has the one top corner rubbing... it was not doing this in the summer or fall but the colder it got the worse it got... what would cause this? its like the frame sagged on one end... but on this same wall there is a nother door going into another room just 2 ft away and it is not showing any signs of this happening... directly above this room is unfinished space and it is cold up there right now... there is a layer of blowin in loose fill insulation could the cold of cause the wall to bow to the point the top rubs now on the door? any ways to fix this? since its ok in the summer i dont want to sand that much and have a larger gap in the summer... thanks!
BlueBSH is offline   Reply With Quote
Old 12-31-2009, 10:23 PM   #2
Could the frost be working on your foundation?
Josh Jaros Remodeling in The Woodlands, Texas www.jarosbros.com
jaros bros. is offline   Reply With Quote
Sealing windows for winter UMWolve General DIY Discussions 5 11-29-2009 07:10 AM
Winter Storage jools Tools 3 11-13-2009 05:43 PM
Sheathing versus Winter Weather Rusnakes Building & Construction 2 07-11-2009 05:17 PM
Hello from Buffalo where winter is WINTER tvlfleming New Member Introductions 6 02-06-2007 07:00 PM
Summer / winter differences... buggie Building & Construction 3 12-24-2005 09:34 AM
