Does Bathroom Wall Tiles Need Cement Board? - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree8Likes
  • 3 Post By Nealtw
  • 1 Post By carpdad
  • 2 Post By ront02769
  • 2 Post By Nealtw
Old 12-15-2019, 02:34 AM   #1
Rewards Points: 110
Does bathroom wall tiles need cement board?
I'm not talking about the shower. I'm talking about if I want to tile the remainder of the bathroom walls. Does this require cement board? Or will drywall work?
farmerjohn1324 is offline   Reply With Quote
Old 12-15-2019, 02:39 AM   #2
retired framer
Rewards Points: 6,438
Re: Does bathroom wall tiles need cement board?
Regular drywall anywhere it won't come into contact with water is fine.
Do not use flat bottom gables with scissor trusses.
Old 12-15-2019, 08:24 AM   #3
Rewards Points: 566
For kitchen splash, I primed the regular drywall first, 2 coats, then thinset.
ktownskier likes this.
carpdad is offline   Reply With Quote
Old 12-15-2019, 11:10 AM   #4
Rewards Points: 1,686
Can even use the pre mix mastic if on walls.
Dave Sal and ktownskier like this.
ront02769 is online now   Reply With Quote
Old 12-26-2019, 09:57 PM   #5
Rewards Points: 110
Does this mean the whole room is smaller? Because of the added thickness of the walls? Any way to prevent this?
Old 12-26-2019, 10:34 PM   #6
retired framer
Is there a reason that concerns you??
Old 12-26-2019, 11:41 PM   #7
Rewards Points: 110
I suppose not. Except maybe issues with electrical boxes especially for lighting fixtures.
Old 12-26-2019, 11:52 PM   #8
retired framer
There are box extenders for that.
mikeyp78 and ktownskier like this.
Old 12-26-2019, 11:53 PM   #9
Rewards Points: 110
Yea I know. Guess there's no reason for it to bother me.
Old 12-27-2019, 12:39 PM   #10
Rewards Points: 566
If there's some thickness differences, it can create an edge that stands proud of the other. You wouldn't want that kind of diffenrence, esp if extending the tiles. With 16" on center studs, half inch drywall is fine but if wider spacing you may want to use 5/8 drywall. You can also use 3/8 if the bays are backed with plywood or such. 3/8 is too thin without the backer for tiling.
Old 12-27-2019, 07:48 PM   #11
Rewards Points: 5,030
Purple board.
https://nationalgypsum.com/products/...ProductID=2413
ron45 is offline   Reply With Quote
Old 12-28-2019, 05:36 AM   #12
Rewards Points: 18
Cement board is the heaviest type of drywall used in tile wall applications and it has the most water resistivity.
Chris Egg is offline   Reply With Quote
Old 12-28-2019, 11:26 AM   #13
Rewards Points: 1,218
If you are tiling in the bath shower area there are other options to use besides drywall, green board, purple board, cement board and pre-fab tub/shower surrounds.
Check out things like DensShield which is gypsum but with fiberglass on the front and back, Durock makes an ultra-light foam tile backer board. JohnsManville makes a product GoBoard which is polyisocyanurate foam with fiberglass on the front and back faces for extra waterproofing and durability.
And of course, there is Kerdi Boards and similar boards like Wedi, Dural Durabase and others.
The only stupid question is the one you DON'T ask!
ktownskier is offline   Reply With Quote
Old 12-28-2019, 12:04 PM   #14
Can you prove that.?
Especially since cement and concrete wick water up even after it's cured
