Does Anyone Have Any Experiance With Fiberglass Windows - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-30-2009, 07:21 PM   #1
Does anyone have any experiance with fiberglass windows
We are going to be replacing our windows. Does anyone have any experience or opinions on brands. I got a price for the Pella fiberglass it was a bit higher than the vinyl. The fiberglass windows sound great to me. Am I just mesmerized with their marketing or are they really great windows?
magic is offline   Reply With Quote
Old 07-10-2009, 08:56 PM   #2
What...are you kidding....I recommend Marvin Infinity first as a replacement window which was consumer reports best buy the Andersen Woodwright Insert Windows are compareable...Pella has horrible service, if did buy their windows good luck if you ever need service because their will not be any. Yes the Pella fiberglass windows are heavy, good luck because you get what you pay for...not the best
EMILY P is offline   Reply With Quote
Old 07-31-2009, 09:22 AM   #3
Fiberglass windows have been around for a while now. They are typically higher in price than that of vinyl. This is partly due to the process that is required to make the various rails and stiles. Their structural properties are very good also. One thing that I did not like about the product is that the master frame and sash corner construction is an epoxy weld(glue) as opposed to a fusion weld on the vinyl products. Keep in mind that there are still mechanical(screw applied) corner conection in viyl products available. These rely on the sealant joint to keep the elements out of the home. You may want to consider vinyl as an alternative. Plenty of dealers out there that can help you out.
I hope that this helps.
fenestrationman is offline   Reply With Quote
replace anderson windows hobbyguy2002 Remodeling 13 12-06-2009 09:34 PM
Windows XP Mode in Windows 7! poppameth PC Repairs & Upgrades 5 04-28-2009 12:18 PM
New Windows installed over old windows Lakehome Remodeling 1 03-14-2009 01:39 PM
How do I install new windows? RickT Carpentry 17 10-12-2006 06:06 PM
