Do I Need A Side Beam For Porch Roof? - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By joecaption
  • 1 Post By spahr1991
Old 09-27-2017, 05:51 PM   #1
Rewards Points: 22
do i need a side beam for porch roof?
not sure what there called but im rebuilding a porch and the home owner wants me to skip replacing the half rotted corner stud on the house for now. the rest of the house framing is good though. can i build the porch without using a side beam just the front beam stacked 2x10 on 6x6 post and 2x6 lag bolted to house? if your wondering i cant replace the house corner stud thats only stacked 2x6's cheap because the main power line is blocking me and needs moved(i stay away from high voltages)
spahr1991 is offline   Reply With Quote
Old 09-27-2017, 05:59 PM   #2
Rewards Points: 18,382
Re: do i need a side beam for porch roof?
Post a picture so we can see what your seeing.
The power company in my area will kill the power to the home and come back later when I call them or shield the wires.
Nealtw likes this.
Old 09-27-2017, 10:00 PM   #3
retired framer
Rewards Points: 6,056
Are we thinking about the deck or the roof?
Old 09-28-2017, 10:08 AM   #4
Rewards Points: 22
the roof, im gonna get a picture today but im taking about the side beam that runs from off the end of the front beam and connects to the house, ive seen them with and without but the current roof framing(over 100yr old) has one
Old 09-28-2017, 10:13 AM   #5
retired framer
A shed roof does not need a beam on the sides.
A gable roof needs beam on each side.
A hip roof needs the beam on each side and one between the posts.
Old 09-30-2017, 11:17 AM   #6
Rewards Points: 22
sorry my phone messed up so i cant get a picture. anyway i did some farther looking at the structure and either way it needs to be fixed before i build the roof so ill be adding a side beam and moving the electric meter anyway due to extending the roof farther in the future
Nealtw likes this.
beam replacement and sistering Bamboozler Building & Construction 22 06-20-2016 01:01 PM
rubber roof over tar & thoughts on quote wfmrules3 Roofing/Siding 13 10-16-2011 10:00 PM
mold on the bottom side of the roof deck overhang mark faultersac Painting 4 09-30-2011 01:52 PM
Roof leak nightmare..... it won't stop amandat37 Roofing/Siding 52 04-22-2011 01:47 PM
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 08:33 PM
