Do I Need To Run Foam Insulation Right Up To The Top Plate? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-16-2010, 07:11 PM   #1
Rewards Points: 548
Do I need to run foam insulation right up to the top plate?
I'm in the process of fitting rigid foam insulation to my basement walls. I just realized that I won't have access to the area in front of the rim joist if I run insulation right up to the ceiling. None of the basement is fully below grade, so I wonder if I need to run the foam all the way to the top plate, or can I get by with running it up to the top of the concrete block? I plan on running a piece along the rim joist, and I can put a horizontal piece on top of the block.
benjamincall is offline   Reply With Quote
Old 08-16-2010, 07:44 PM   #2
Rewards Points: 548
As you can see, my rim joist is two 2x8s stacked on edge with no sill plate.
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
Rigid Foam Insulation over existing wood siding Hexar Building & Construction 30 04-23-2010 07:15 PM
Covering rigid foam insulation in furnace area looking4ideas Building & Construction 4 12-30-2009 05:49 AM
Closed Cell Spray Foam insulation and hiring a contractor. Spud Building & Construction 2 10-14-2009 09:03 AM
Exterior Foam Insulation Help??? teachtech Building & Construction 3 11-29-2008 10:19 AM
