Do I Need To Flash This? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-26-2009, 11:58 PM   #1
Do I need to flash this?
I'm residing my 1980 house. Tearing off the aluminum and putting up Hardi Plank.
You can see pictures here http://www.diychatroom.com/f49/new-h...d-aargh-48959/
My question is.... On the wall I'm about to tackle there is a concrete block chimney. You can see in the pic that the existing aluminum butts right against it. I hope to use a vertical trim board against the concrete but suspect I should use some type of flashing. Any advice?
derf36 is offline   Reply With Quote
Old 07-27-2009, 12:08 AM   #2
Registered User
Termite's Avatar
I doubt that flashing's in order. Refer to the Hardie installation guide to be sure though. My bet is that you leave a gap about 1/8" wide and caulk the seam. The aluminum you have now has that end detail to make the installation look clean.
Old 07-27-2009, 10:41 AM   #3
I have gas!
Clutchcargo's Avatar
Rewards Points: 2,010
From that picture, the siding seems to be in pretty good shape. Why are you residing?
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 07-27-2009, 11:45 PM   #4
that's a good question and one I've asked myself a few times over the past few weeks.
The house was built in 1980. Over the past two years we've gutted inside and the outside was untouched. Even though the existing aluminum is in fine shape, it was time to do the windows and modernize outside so here we are.
Seemed like a good idea at the time and I'm happy with the result so far but, man, is it a big job.
Old 07-28-2009, 01:25 PM   #5
Registered User
Rewards Points: 526
Generally, one would add trim (1x2 cedar) vertically, to both get a better caulked seal against the block and it looks finished. (As a border flowerbed at the yard fence, or base inside a house. A transition to the eye between two dis-similar textures. Be safe, G
how to download flash movies emilyanderson Networking 1 07-10-2009 06:01 AM
Arc Flash ctsmiths Electrical 53 01-27-2009 05:57 PM
What type of metal to flash chimney and masonry wall? Max1119 Roofing/Siding 6 05-03-2008 05:58 AM
Flash this? sandyman720 Roofing/Siding 2 02-07-2008 10:01 AM
Comfortmaker RPJ - 1 Flash - Nothing ON olgranddad HVAC 29 01-02-2007 09:23 PM
