Do I Need Attic Ventilation? - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-14-2015, 06:55 PM   #16
Registered User
Rewards Points: 526
Your 18' x 18' forms a hip at top, no horizontal ridge. Add an 8x8 turtle vent: http://www.owenscorning.com/roofing/...ic-slant-back/ on each side to meet the 1/300 min. code requirement as the faced 4" attic deck insulation is probably a vapor barrier- fiberglass or foam board? Open the foamed over hole if you can, add screening for bugs.
Gary
Ridge vent vs mushroom fan gtothek Roofing/Siding 8 03-30-2015 03:12 PM
Attic Ventillation Problem. Why Now? Hubs Roofing/Siding 2 03-19-2013 11:23 AM
Attic ventilation tmaher HVAC 5 06-09-2011 11:54 PM
Improve attic ventilation? Greenmaze Roofing/Siding 28 07-22-2010 03:16 AM
Powered Attic Fan question spup345 Roofing/Siding 9 06-30-2008 09:10 PM
