Different Length 2x8's - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree7Likes
  • 1 Post By Yodaman
  • 1 Post By mark sr
  • 4 Post By comfun1
  • 1 Post By Domo
Old 04-14-2019, 05:21 PM   #1
Rewards Points: 66
different length 2x8's
Hello all, was squaring off my deck framing. and it wasn't squaring off quite right until I decided to measure the 2x8's that I had purchased at Lowe's. bought two batches at different days. there's at least a 1/2" difference between the planks. I noticed that on the one's that looked damper, that they were 1/2" longer. Is this normal? Do I just cut the longer one's to use, or wait till they dry? thanks
woodypecker is offline   Reply With Quote
Old 04-14-2019, 05:29 PM   #2
Property Mgt/Maint
Rewards Points: 6,172
Re: different length 2x8's
It is common for regular lumber to vary in length.
Should check your ends for squareness, splits and length before installing.
ZEW496 likes this.
[political signature removed]
Yodaman is offline   Reply With Quote
The Following User Says Thank You to Yodaman For This Useful Post:
woodypecker (04-14-2019)
Old 04-15-2019, 05:21 AM   #3
retired painter
Rewards Points: 864
If you wait for them to dry they might twist. I'd cut and nail them up in a timely manner. When I built our deck I made multiple trips to the big box, twice I picked up the same nice looking [straight, no knots] 2x6 to only realize it was almost a foot shorter than the rest. I assume it was a return.
Nealtw likes this.
mark sr is offline   Reply With Quote
Old 04-15-2019, 06:36 AM   #4
retired framer
Rewards Points: 16,220
Lumber is rough cut at something just over the 2 foot mark, every saw mill nay may have a different measurement. Lumber is pulled up the table on chains with a tab for each board . if one chain is tighter than the rest. non will be square.
Do not use flat bottom gables with scissor trusses.
Old 04-15-2019, 06:50 AM   #5
Rewards Points: 156
The only lumber I know of that is cut to the precise length are precut studs.
ZEW496, Yodaman, mark sr and 1 others like this.
comfun1 is offline   Reply With Quote
Old 04-15-2019, 12:52 PM   #6
Contractor/Engineer
Rewards Points: 1,092
...and STILL you better check them!
Mike Milam likes this.
Domo is offline   Reply With Quote
Old 04-18-2019, 08:29 PM   #7
Rewards Points: 1,332
Overall, if you buy Pt lumber, you will have issues with anything other than two bye four bye eight. That said, mostly ONE end will be square. Just measure from there and cut to length. Worked on deck yesterday, two bye tens and eights, lumber was plus or minus a quarter of an inch in width, never less than advertised length, but up to an inch over. No worries as long as you understand what you will be getting. Ron
ront02769 is offline   Reply With Quote
1/2" NPT brass nipple with 3 1/4" length needed. noone Plumbing 10 08-09-2013 05:49 AM
Should I splice to shorten length? Troy32 Electrical 11 12-08-2012 08:13 PM
Maximum hardwood flooring length EE_Steve Flooring 3 10-20-2012 10:51 PM
LED strip length? Karpiel73 Electrical 4 04-29-2012 09:46 PM
AC Temp drop over plenum run length BlueBSH HVAC 23 06-22-2010 08:10 AM
