Demolotion Of Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-26-2014, 12:59 PM   #1
Rewards Points: 28
Demolotion of wall
I have a wall that divides up the kitchen, dining room, foyer and living room. I plan on removing it this weekend. I was told it is not a weight bearing wall as it looks like a regular interior wall with a built closet on one side.
What is the easiet way to remove the drywall, wood frame and move the electrical wire out the way.
Any tools that would make the demo easier as I will be saving about 800 by doing this myself.
FastEddie26 is offline   Reply With Quote
Old 06-26-2014, 01:05 PM   #2
kwikfishron's Avatar
Rewards Points: 144
Originally Posted by FastEddie26 View Post
I was told it is not a weight bearing wall.
Told by whom and how did they determine that?
kwikfishron is online now   Reply With Quote
The Following 3 Users Say Thank You to kwikfishron For This Useful Post:
gregzoll (06-26-2014), Msradell (06-26-2014), oh'mike (06-26-2014)
Old 06-26-2014, 01:35 PM   #3
Rewards Points: 28
The realtor I worked with has been working in that neighborhood since the 70s. He has seen other folks do the change we are proposing. I'd like to verify it is not load bearing myself.
I have attached the image and the wall in question is the wall between the kitcken, dining room, living room. It does not touch an exterior wall.
Old 06-26-2014, 01:50 PM   #4
Retired Moderator
Rewards Points: 7,174
A picture from outside of the house and from inside of the attic will be needed--
If the house has self supporting roof trusses,it might be a partition--
That closet wall might be supporting headers that hold up the ceiling,if it is conventional framing.
A Saws All to cut nails --a flat bar --and trash bags is about it for tools--but you really need to get someone in that knows structure--
I've seen the result of pulling out a bearing wall improperly----think big money wasted---BIG.
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
BigJim (06-26-2014), gregzoll (06-26-2014)
Old 06-26-2014, 01:59 PM   #5
Ole Wood Worker
BigJim's Avatar
Rewards Points: 518
Are you talking about the wall between kitchen and dinning AND the wall with the closet? If so it would be best to go up in the attic and see if ceiling joists are joined on top of the walls, if so then it is a weight bearing wall and can not just be removed, if the ceiling joists just lay cross the wall, you should be OK provided the wall isn't being used to hold any other type of weight like an AC or kickers for the rafters and such.
It would be best to make sure the walls are not weight bearing before removing, it sure is hard to repair a ceiling once it comes down, not to mention maybe a hospital bill or a funeral.
New members: Please consider adding your location to your profile.
Lawyers believe a man is innocent until proven broke.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
Old 06-26-2014, 02:08 PM   #6
Rewards Points: 144
You have some good advice.Why would you take the word of a realtor on the structure of your home?
mako1 is offline   Reply With Quote
The Following User Says Thank You to mako1 For This Useful Post:
Old 06-26-2014, 03:57 PM   #7
GBrackins's Avatar
Rewards Points: 2,108
not all homes are built the same way. follow the advise given above.
good luck!
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 06-26-2014, 03:59 PM   #8
Rewards Points: 28
I've gotten on the phone with the structural engineers to inspect this. It will run about 500 for the inspection in case someone out there is curious.
Old 06-26-2014, 06:23 PM   #9
Ole Wood Worker
BigJim's Avatar
Rewards Points: 518
If you can find a framing crew you could pay the head worker to tell you if the walls are loaded or not. If you can take some pictures of the top of the walls from the attic maybe we can tell if it is loaded or not.
Jim
Old 06-26-2014, 06:32 PM   #10
Rewards Points: 12
It's easy to tell - take a big light up to the attic, though, in case there are hostile squirrels. You may have to move the insulation back a bit. A bearing wall will have a 2 joists together, in a line over that wall. It should not be under an air conditioning unit or heater. If the attic is plywooded over, there should be a line of 'extra' nailing where the joists lap.
VChucks is offline   Reply With Quote
Old 06-26-2014, 07:39 PM   #11
Rewards Points: 144
VChucks: Where the hell do you get your info from?Thr internet or are you just trying to be fummy?
The Following 3 Users Say Thank You to mako1 For This Useful Post:
gregzoll (06-26-2014), Msradell (06-26-2014), ront02769 (06-26-2014)
Old 06-28-2014, 11:43 PM   #12
Rewards Points: 28
I got an engineer to come out and verify the walls are not load bearing.
Demo will begin tomorrow, and what are some good tricks to demo a wall quickly?
Old 06-28-2014, 11:52 PM   #13
Ole Wood Worker
BigJim's Avatar
Rewards Points: 518
You might want to go up in the attic and pull the sheet rock nailers off the top of the top plates, if not it is going to tear your sheet rock up. Using a sheet rock knife cut the sheet rock tape where the walls meet the ceiling or there is a good chance you will mess up the sheet rock.
Jim
FastEddie26 (06-28-2014)
Old 06-29-2014, 07:09 AM   #14
Retired Moderator
I use a Saws All to cut the nails at the bottom plate---a Milwaukee demo blade will cut wood and nails---once the stud is loose--pull it out--
Put the blade in upside down---this allows you to make clean flush cuts at the floor and ceiling--
Top and bottom plates are easiest to remove if you cut them into short sections--16" long---then there is only one set of nails ---
Creating doorways/supporting wall issues NWVintage Remodeling 2 12-19-2012 04:19 PM
Retaining wall work-- what approach? emcelvaney Landscaping & Lawn Care 2 09-24-2012 08:49 PM
Retaining wall problem FMS Landscaping & Lawn Care 6 07-04-2011 07:42 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
