Decks - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-27-2010, 04:11 PM   #1
Decks
40 years ago I built a deck using beams and no joists. the code said beams 4 ft on center...I put them 3 1/2 feet on center so decking would be more solid. is this still an okay way to go without the need to also use joists ?
i plan to use 3/4 inch thick ipe mahogany this time...last tiem useed 1 1/2 thick redwood
Les
les kishler is offline   Reply With Quote
Old 06-27-2010, 05:02 PM   #2
Where are you located ?
What did you use for decking ?
Old 06-27-2010, 06:13 PM   #3
Registered User
Rewards Points: 526
All depends on the species group for their rating, page # 195: http://books.google.com/books?id=idB...floors&f=false
This is normally for interior floors with a possibly different load rating, check with your local Building Department.
The new Deck Code: http://www.lancova.com/deckinfo.pdf A lot has changed in the ledger attachment, piers, footings, bolting, etc.
Be safe, Gary
Old 06-28-2010, 12:23 PM   #4
deck question
last time 1 1/2 inch thick redwood...this time 3/4 inch ipe mahogany
Salt water resistant decks stains mlopez Building & Construction 5 09-13-2010 11:14 AM
Troy Built engine:what mower decks will fit? boone722 Tools 3 09-21-2008 10:23 PM
Decks -Beams vs Posts sandyman720 Building & Construction 4 04-13-2008 10:30 AM
decks and patios dave_kcmo Site Help and Suggestions 0 10-23-2005 11:16 PM
