Deck Undercover Protection - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By lenaitch
Old 01-03-2017, 10:06 AM   #1
Rewards Points: 1,226
Deck undercover protection
Hi. I enjoy smoking meats and do so at our walkout patio from the basement, which is under a wood deck. Can you recommend an inexpensive, temporary solution to accomplish this? I would not be opposed to laying a tarp on the deck and I could place screws along the edges that would protrude enough to—hopefully—secure it at each eyelet. These could be placed close-enough to the deck edges that I would not have concern about people stepping on them. I could use a tarp that would overshoot my required dry space by a 3’ perimeter. I’m in Ohio, so we get snow and ice but I could shovel it during times that the tarp would be in place. Would this work?
If I chose something more permanent could I affix corrugated steel roof panels under the deck and, if so, how much of a slope would I need for a 10’ run?
Thanks!
bfletcher7 is offline   Reply With Quote
Old 01-03-2017, 11:28 AM   #2
Rewards Points: 4,456
Re: Deck undercover protection
Not quite sure I understand - you're looking for a way to keep the weather off you while you're under the deck?
stick\shift is offline   Reply With Quote
Old 01-03-2017, 11:36 AM   #3
Yes; the first-floor deck is 12' X 20' and I'm looking to keep an approximate 10' X 10' area at the walkout basement dry that's below the deck.
Old 01-03-2017, 03:01 PM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 240
Ayuh,.... I'd just do the 3 or 4 sheets of tin screwed up from below,....
An inch in 10' is plenty of slope,..
Bondo is online now   Reply With Quote
Old 01-03-2017, 05:21 PM   #5
Usually Confused
lenaitch's Avatar
Rewards Points: 952
Or corrugated translucent fibreglas panels.
Bondo likes this.
lenaitch is offline   Reply With Quote
Old 01-04-2017, 07:22 AM   #6
Rewards Points: 18
They sell a vintl siding type of product specifically to do what you are trying to accomplish. At the ends, there is a gutter that leads to a downspout. Simple tl install and not expensive. Call your local siding dealer.
Sent from my LG-D415 using Tapatalk
jeffmattero76 is offline   Reply With Quote
Old 01-04-2017, 08:30 AM   #7
Rewards Points: 540
Plastic panels already suggested would be my choice for easiest install, light for one thing, with plenty of slope (3-4" per 10' if headroom allows) for as much self cleaning as possible with rain. Dust collected up there will be no joke.
carpdad is offline   Reply With Quote
Old 01-05-2017, 04:34 PM   #8
Thanks for the feedback; I'll grab some panels from HD and add a slope.
Old 01-06-2017, 04:29 PM   #9
Do I need to seal along the edge of each adjoining panel? And by how much do they need to overlap? Thx.
Old 01-06-2017, 05:43 PM   #10
Rewards Points: 18
I would suggest that you follow whatever installation instructions came with the panels.
Old 01-06-2017, 07:04 PM   #11
Bondo's Avatar
Rewards Points: 240
Ayuh,.... Usually the edges are ribs, which one goes over the other, 'n a screw down through to hold it,....
No sealant necessary, water would have to flow Up, over the ridge on the lower panel,...
'n We all know water flows downhill,...
Deck Stain? pomlady7 Painting 13 05-24-2014 05:58 PM
Deck renovation Project - Advanced DIY'er Please Advise OhmZoned Building & Construction 21 05-04-2014 10:32 PM
Cedar deck help mickbiv Painting 11 08-08-2013 10:21 PM
TREX decking extremely disappointing KHL General DIY Discussions 266 07-05-2013 12:26 PM
tiling deck of a 5 ft corner tub level with tub deck Blue Falcon Carpentry 16 09-28-2011 01:55 PM
