Deck Suggestions - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-23-2009, 01:19 PM   #1
Deck Suggestions
Hey there...I am investigating adding a 9x20 deck to the front of our house. I am thinking 4 6x6 posts (mounted on sonotubes below frostline) for front support. We'd eventually like to put a gabled roof over it (one thing at a time)...So I thought the four front posts could serve as support, along with 2 6x6's at the house..
This is a rough make up of the overall design... I am thinking 2x8's might be too skimpy....any advice is greatlyappreciated...
nursenuttree is offline   Reply With Quote
Old 06-23-2009, 03:16 PM   #2
Registered User
Rewards Points: 526
1. Could you post a picture of the proposed location?
2. Do you have a basement?
3. Floor joists- 2x8 16"o.c. span 12'8" 2x6 16"o.c. span 9'9"
4. Ceiling joists- 2x6 24"o.c. span 11'3"
5. Roof rafters- 2x6 24"o.c. span 11'8"
Read this to prevent frost heave: http://books.google.com/books?id=1gg...num=3#PPA31,M1
Be safe, G
Old 06-24-2009, 03:28 PM   #3
Rewards Points: 1,910
The footings will need to be bigger than if it was and uncovered deck so if you think you'll put a roof on in the future then have the footings sized for the roof now.
Building a new deck......suggestions? thoughts? Rhizzlebop Building & Construction 38 06-24-2009 05:07 PM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 11:17 AM
Enlosing underneath the deck? Need suggestions and any help you can give. KoolAid Carpentry 3 04-17-2008 07:05 AM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
