Deck Screws Vs Hidden Fasteners - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-22-2016, 03:42 PM   #1
Rewards Points: 191
Deck Screws vs Hidden Fasteners
What is your final thought mates?
going 5/4" x 6" southern yellow pine pressure treated.
do i got with just top screws and 2 per board or do i go for a a hidden fastener so it looks real clean and finished.
please let me know. i worry about about strength and allowing too much movement from hidden fasteners.
rygar is offline   Reply With Quote
Old 08-22-2016, 03:51 PM   #2
Rewards Points: 4,456
Re: Deck Screws vs Hidden Fasteners
I've only seen hidden fasteners used on composite. Maybe people who buy PT decking generally are not willing to spring for the added cost of the hidden fasteners?
stick\shift is offline   Reply With Quote
The Following User Says Thank You to stick\shift For This Useful Post:
rygar (08-22-2016)
Old 08-22-2016, 03:54 PM   #3
Rewards Points: 191
maybe something like this where you attach deck screw from the side?
http://www.lowes.com/pd/CAMO-Marksma...5-80f56165668d
Old 08-22-2016, 04:19 PM   #4
I've seen hidden fasteners before just not seen anyone use them on PT. I would think it would work just fine.
Old 08-22-2016, 10:30 PM   #5
Rewards Points: 135
I used Camo fasteners on 2x6 pt material. I laid about 550 Sq ft in July 2014, and it looks clean and sister holding up well so far.
ptarmigan61 is offline   Reply With Quote
The Following User Says Thank You to ptarmigan61 For This Useful Post:
rygar (08-23-2016)
Old 08-23-2016, 01:05 AM   #6
Rewards Points: 191
how was the gap? i know camo wont let you butt up the PT wood
Composite vs wood deck screws cranedk Building & Construction 6 11-26-2015 04:47 PM
Deck screws Renoboy General DIY Discussions 9 08-29-2015 01:03 PM
Loose stainless steel deck screws drtbk4ever Building & Construction 17 06-19-2012 10:26 AM
Refinishing / Repairing Deck: Screws vs. Nails? superhandymom Building & Construction 1 05-10-2010 03:08 AM
DECK decking nails vs screws ... christian15213 Building & Construction 8 05-02-2005 08:51 PM
