Deck Rebuild Questions - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-12-2019, 02:35 PM   #1
Rewards Points: 50
Deck rebuild questions
I'm back with another deck project . This time is is 5x10, and again very close to ground level. Previously it had true 4x4 acting as beam and joists. Could I do 4x4 again in this configuration, any ideas, thoughts or better suggestions??? Thanks as always!
shtiv is offline   Reply With Quote
Old 04-12-2019, 02:37 PM   #2
retired framer
Rewards Points: 6,198
Re: Deck rebuild questions
A deck should be 6" below the door. Concrete.
Do not use flat bottom gables with scissor trusses.
Old 04-12-2019, 02:40 PM   #3
Rewards Points: 50
Hoping to use composite as I am on the other deck, any way of making it work and having a decent design?
Old 04-12-2019, 02:53 PM   #4
Hammered Thumb
Rewards Points: 950
What's your location? I have to say the rot on both these decks is intensive = on grade.
Also, those piers look like 8" prefab blocks just set there. Main deck using the same ones?
3onthetree is offline   Reply With Quote
Old 04-12-2019, 02:57 PM   #5
Rewards Points: 50
Also, those piers look like 8" prefab blocks just set there. The main deck using the same ones?
Just outside Seattle, WA. The plan is to put in new piers, not quite sure what I should do however as far as those, was thinking of doing piers with anchor bolt and wood to concrete base bracket, prefer not to do overkill if not necessary.
Old 04-12-2019, 03:03 PM   #6
retired framer
How old is that deck and how long has it been home for all kinds of thing you don't want near the house.
That deck needs 16" OC.
Make your beams out of reinforced concrete with a 2x4 on top, maybe???
Old 04-12-2019, 03:06 PM   #7
Rewards Points: 50
Unsure of decks age.
Old 04-12-2019, 03:13 PM   #8
retired framer
if you use lentels with a 2x4 on top you could do 19" on center.
https://www.homedepot.com/p/72-in-x-...3140/100350695
Old 04-12-2019, 03:17 PM   #9
Rewards Points: 50
I do not mind doing them closer together, just want to make sure it holds up and is designed correctly.
Old 04-12-2019, 03:31 PM   #10
retired framer
Treated 2x4s with the peal and stick on, over concrete would give it a chance of lasting.
Deck planning questions theshallowbay Building & Construction 7 04-22-2018 11:22 PM
Deck Railing Post rebuild project JaneD Building & Construction 2 10-01-2014 12:30 AM
Deck rebuild taylorjm Building & Construction 15 05-25-2014 11:07 PM
Deck Questions burnt03 Building & Construction 2 08-08-2010 01:11 AM
New deck staining questions sk8z Painting 7 11-14-2007 07:45 PM
