Deck Rebuild Advice - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-10-2017, 06:00 PM
Rewards Points: 4
deck rebuild advice
Hi, I have a multi-level deck that I am rebuilding. lower level is over an entrance to a small basement under an addition that is inaccessible from the house and previously had a metal bulkhead door that was removed. second level is 1 step up and is over another metal bulkhead that is still attached. I would like to lower upper level to match the lower deck. Problem is removing the bulkhead and still having access to the basement thru the deck for a rare situation such as removing a water tank or boiler. Anyone ever make a trap door or access door through a deck? The lower level has a trap door but it leaked. Dont want that issue in the full basement. Also, need opinions on fibron composite decking. Too many bad reviews of trex and fibron is a little more affordable. Thanks for the help, Jerry
jerryjam is offline
Old 05-10-2017, 08:53 PM
Usually Confused
lenaitch's Avatar
Rewards Points: 190
Re: deck rebuild advice
Photos will be helpful (I think you need at least one post, but I'm never sure). By "bulkhead", do you mean some kind of vertical hatch? You mention that an existing deck hatch leaked - is your deck a tradition plank deck or some kind of solid waterproof surface.
A problem with hatches in a deck (I'm talking plank deck) is as the wood shrinks the various elements will shrink differently and the hatch lid ends up uneven and loose and a tripping/toe stubbing hazard. Do you want the hatches anchored down or just resting closed? There are also issued of hinges and lifting hardware being tripping hazards but there are probably a few options around that. If you want to be able to remove boilers and water tanks, how big are you envisioning. I have no clue if there might be Code issues with hatches.
No experience with Fibron. I have TimberTech and so far so good (only 2 years)
lenaitch is offline
Old 05-11-2017, 06:33 PM
Rewards Points: 4
Ive decided not to lower the deck. way too much work. still going to build an access hatch over bulkhead doors and a small one over the opening without doors. Here is what im up against
jerryjam is offline
Old 05-13-2017, 02:24 AM
Rewards Points: 6
It looks nice.
MichaelVGarry is offline
Advice on how to run deck boards BigHendy Carpentry 11 04-02-2016 10:32 AM
Update on my deck rebuild...more questions... mgh-pa Building & Construction 6 07-01-2011 08:30 AM
Need to build a new deck on a end-unit town house, need planning advice steppinthrax Carpentry 3 11-30-2010 11:48 AM
Need advice on deck flashing, water stain Durt Ferguson General DIY Discussions 4 04-20-2010 06:09 PM
