Deck Privacy Wall Help - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-14-2014, 11:05 AM   #1
Deck privacy wall help
Hello,
Saw a post like this, but it sounded as if the poster was more along in the process than me. I have a 10X20 deck on the back of the townhouse, 12' off the ground. On the 10' side that adjoins the neighboring townhouse (ours is an end unit, I'd like to frame for a privacy screen, perhaps a pergola-esque overhang that would go the the 10' and overhang a few feet.
Possible?
How? would you use metal brackets to secure it, like down the outside main deck posts, or will that not work?
Thanks for any ideas or pointers to ideas.
benb is offline   Reply With Quote
Old 07-14-2014, 11:11 AM   #2
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 12
Do you have a pic of the area?
Old 07-14-2014, 11:12 AM   #3
JUSTA MEMBER
Rewards Points: 1,456
Benb: Without seeing it, really cannot advise on anything .
Securing it is a must.
ED
de-nagorg is offline   Reply With Quote
Old 07-14-2014, 11:14 AM   #4
no, just decided to post, standard 10X20 deck with main posts that stop at joists and 4X4 rail posts bolted into joists, at corners and one in the middle.
Old 07-14-2014, 11:18 AM   #5
I'm not building off anyone's replies, just looking for ideas if anyone has done a project like that.
Old 07-14-2014, 11:23 AM   #6
Rewards Points: 18,376
Got a HOA to deal with?
Old 07-14-2014, 12:13 PM   #7
not that I'm concerned about
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 04:11 PM
Can I remove this wall? limited60 Remodeling 9 06-05-2012 02:32 AM
Deck: gap from 1st deck board to wall frankkerfoot Building & Construction 2 05-16-2012 09:49 PM
Deck stairs over existing stone retaining wall steps joshg3p0 Building & Construction 16 05-03-2012 12:30 AM
