Deck: Post-to-joist Attachement - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-15-2009, 12:01 AM   #1
Question
Deck: post-to-joist attachement
I am planning on building a floating deck in the near future using precast cement piles. I plan on putting a treated 4x4 post vertically into the pile. Now this is where my question is....Do I attache the horizontal joists to the side of the 4x4 post using appropriate bolts or do I place the joists on top of the post? The reason I would like to attache the joists to the sides of the vertical 4x4 posts is so that I do not need to go through the hassle of making sure all my piles are are the same level. If I place the joists on top of the 4x4 post how does one secure it to the post. I am probably going to use 2x6's as my joists. The deck height is very minimal...(ie: ~1ft). Ideas??? Suggestions???
alifor is offline   Reply With Quote
Old 06-15-2009, 06:39 AM   #2
Eliminate your 4x4s. Run a double rim joist and use hangers to attach your stringers to. The double band joist will also give you a secure piece of framing to attach your posts to with lags or through bolts. Don't notch them, it weakens them. Make your self a water level if you don't have a laser level. Buy enough clear plastic hosing for the project and fill it with colored water. Add a teaspoon of dishsoap to help it flow. You can use it to level all your concrete footings so they are perfect. If you mess up, just cut a few pressure treated shims to level it.
Josh Jaros Remodeling in The Woodlands, Texas www.jarosbros.com
jaros bros. is offline   Reply With Quote
Old 06-15-2009, 08:38 PM   #3
Registered User
Rewards Points: 526
Working alone: http://factsfacts.com/MyHomeRepair/WaterLevel.htm
http://books.google.com/books?id=1gg...num=3#PPA31,M1
Be safe, G
Old 06-16-2009, 11:53 AM   #4
I have gas!
Clutchcargo's Avatar
Rewards Points: 2,048
The AWC is an excellent resource and they have a deck publication.
http://www.awc.org/Publications/DCA/DCA6/DCA6.pdf
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 06-16-2009, 12:33 PM   #5
I'm attaching my 4x6 posts to 2x12 beams
I had intended on notching the 4x6's to allow the 2x12's to sit on the posts. Then the joists (6' span) will hang off the beam & the ledger on the house
I've never used a 4x4 as a beam
How far apart are your beams?
How far will your joists span?
Post detail for raised covered deck jogr Building & Construction 3 05-16-2009 07:46 AM
seal base of deck post webber123456 Building & Construction 13 11-04-2008 10:42 AM
Poor Deck Post Anchors Schnelltdi Building & Construction 5 04-06-2008 11:14 AM
Connecting rim joist to deck ovahimba Building & Construction 5 01-19-2008 08:33 AM
Deck post footings Outbacker Building & Construction 8 02-11-2006 05:20 PM
