Deck As Impervious Surface - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 2 Post By de-nagorg
Old 10-22-2017, 09:09 PM   #1
Deck as impervious surface
Having difficulty getting the county to approve a deck as my subdivision's rated for 22% of the lot as impervious surface. Well I'm already at 23% or so and they're counting the proposed deck (no roof, etc.) as additional impervious surface. I'm arguing it's not. There's gaps between the decking. Ground underneath will still be absorbing water as normal. Anyone else run into this issue?
barnesec is offline   Reply With Quote
Old 10-22-2017, 09:20 PM   #2
JUSTA MEMBER
Rewards Points: 4,190
Re: Deck as impervious surface
You may end up hiring a lawyer to argue your point, but I would get exact explanation from the code officer.
Sometimes they convince themselves that you are right when trying to explain.
Besides often they are confused and just say no before thinking it out.
You are correct a proper built deck with spaced planks is not impervious, might have a slight pooling problem though, unless you plan a proper drainage.
ED
chandler48 and Nealtw like this.
de-nagorg is online now   Reply With Quote
Ledger on 2 storey deck rotting, other issues jmetrail Building & Construction 7 09-08-2017 03:07 PM
Deck over roof --Help, I need product to repair roof w/o deck tearoff jaes Roofing/Siding 5 08-09-2017 04:34 PM
Fill-in low spot on painted membrane deck surface eastvantrading Painting 1 01-19-2015 09:11 AM
Building Floating Deck over ground and Concrete slab jagnew Building & Construction 2 05-27-2012 12:10 PM
